Conversion folks please list your conversion in here
Old 08-03-2004, 11:04 PM
  #201
Redline-Motorsports's Avatar
Holy ****! What a list!
I am building a 62' Chevy2 Pro Touring car. It is built on an Art Morrison 2" x 4" tube chassis with a C5 front suspension and a Triangulated 4 bar rear suspension.
The motor is a 427 ci Darton block that is fed with two T60-1 intercooled turbos through a sheet metal intake. Behind this motor is going to be a beefed up Viper T56 tranny.
The car sits 5 3/4" off the ground and has 295/35/18's in the rear and 245/35/18's up front.
I just got my Big Stuff 3 DFI unit the other day. Car should be running by later October and completed by early summer.
Shooting for front cover of Car Craft magazine, a trip to the Power Tour, 9 sec 1/4 miles, and some serious autocross racing with the AC on!
Stay tuned for further details!
Old 08-22-2004, 07:13 AM
  #202
KatfishRacing's Avatar
We converterd a 1984 Z28 Camaro into an ls1/t56 powered NASA Road Race car....in 9 days!!!
Old 08-23-2004, 10:30 AM
  #203
Wings's Avatar
69 Camaro Z11 Pace Car
LS1-T56
Just gathering parts right now
Old 08-30-2004, 06:30 PM
  #204
gnx7's Avatar
'93 RX-7 with '01+ LS1/T56. home ported heads and big hydraulic cam, LT headers, PCM mods, ported TB. Should make the 2750lb car scoot.
Hope to be done before the end of 2004. Need to paint engine bay, buy driveline and then build the car. Lots to do.
-GNX7
Old 09-05-2004, 01:52 PM
  #205
OLETIMER's Avatar
Unhappy 93 Engine In 90 Chassis.need Help?
Please list:
1) Vehicle receiving the swap
2) Your new combo, LS1; A4 or M6, etc.
3) Link to pics if you have any
We can create a list and link it to the top of this forum as a guide.
I wanted to thank everyone who has gotten the word out about this particular forum, I wasn't sure if it would have an audience but it appears that there is one.
Bonus points if you have info or pics of that 59 Cadillac converstion with the turbocharged LS1 from New Jersey!!!!
THANKS JOHN..
I HAVE A PROBLEM I HOPE ICAN GET SOME HELP WITH. DEALER DOSN`T WANNA BE BOTHERD.
I INSTALLED A `93 2.5 ENGINE IN MY `90 S-10 P/U. ALL IS FINE EXCEPT THE FOLLOWING:
I WISH TO RETAIN THE 93 DISTRIBUTOR BECAUSE IT LACKS THE "HALL EFFECT SWITCH". I HAVE FOUND IN THE PAST THAT THIS ITEM IS A SOURCE OF TROUBLE.
THE PROBLEM IS, THE PLUG IN THE `90 HARNESS IS DIFFERENT. IT HAS THE SAME NUMBER OF CONNECTIONS (4) AS THE 93. I NEED TO KNOW, CAN I SPLICE THE PUG FROM THE 93 WIRING HARNESS, INTO THE 90, IF I FOLLOW THE COLOR CODES. ALSO, DO I HAVE TO USE THE 93 ECM. I HAVE BOTH, 93, AND 90 ECM`S. SURE HOPE I GET SOME REPLIES ON THIS ONE. NO ONE HAS BEEN ABLE HELP ME YET. THANKS..
OLETIMER
Old 09-05-2004, 08:29 PM
  #206
55LS1's Avatar
Please list:
1955 chevy 2 door sedan
422ci LS1/M6/12 Bolt w/4:11's
253/257 Cam, TEA Stage 3 AFR's, LSX 90 setup, Custom DP N2O setup
Mini-tubbed, sitting on 28x13.5x15 ET streets
Weight: 2900-3000lb
Custom built by my shop, pics to come
Old 09-05-2004, 08:52 PM
  #207
Josh Kersten's Avatar
92' Camaro Rs (3.1v6/5sp)
LS1;M6(T56)
Project is all done. Still trying to find the right throttle cable. I modified the 92'stock one for now. I tried one out of a late model truck(5.3/6.0) it was too short, but had the correct ends though. Anyone with advice please reply. Thanks
Old 09-12-2004, 01:03 AM
  #208
ls1 1990 VN's Avatar
finished xmas 2002.
90 Holden commodore (v6 auto,3.08 diff)
LS1 vette crate mtr,t56,4.10 Lsd. 30mm sway bar,caster camber kit,nolathane,king spr low 2",,adj koni,s,adj panhard,330mm fr rotors wilwood 4spot,custom headers+sump+hyd clutch.aft mrkt ecu. 3qrt Accusump.
H/S rockers,Kelford 222/222-112 cam,ti retainers,Pattiot gold dual spr, 7.40" push rods,double timing chain, Extreme clutch,lightened f/wheel.Mahle pistons,Scat H Rods,25%u/d pulley,LS7 Caddy race lifters,TSP 5.3 stg 2.5 heads shaved 30thou, ARP 2000 bolts,Lucus 42lb inj, Fast 102 intake, PTM 102 T/B
Old 09-13-2004, 10:57 AM
  #209
KozanBMW's Avatar
1999 BMW Z3
Want to Do:
LS1 Conversion
T56
I was one day away from ordering 20k worth of parts to build a M Roadster, when I read up a little more on this concept. Sounds outstanding. Mixing BMW Luxury and ride with American Muscle. A winning combination.
Old 09-19-2004, 12:24 AM
  #210
NX74LS6's Avatar
1974 Chevy Camaro
'02 LS6/4L60E
3:42
a/c delete
batt relocation
ASA road racing cam
engine dyno'd 375 rwhp in '69 camaro(previous owner settup)
weight reduction where possible
Old 09-21-2004, 12:45 PM
  #211
IMD
IMD's Avatar
1997 S10
98 LS1 A4
http://www.stlhosting.com/upload/truck002.jpg
cyclepunk@gmail.com
Old 09-21-2004, 05:50 PM
  #212
5.7LImport's Avatar
{Car} (1) 1991 Nissan 300zx (NA)
{Combo} (2) LS1 M6
{Pics} (3) Updated pics...
CURRENT AVAILABLE IMAGES:
- The Z
- New Gauges
- Swap Progress as of 2/6/03
- Swap progress as of October 2, 2004!
- My new, badass wheels!
Swap started: December 26th 2002
--- huge setbacks between then and now
Completion date: October 1, 2004!
Swap will be totally complete with/when these details are all added up:
Engine/Performance:
- 1998 LS1/M6 combo (stock) from WS6 Trans-Am
- Custom Iintake
- Hypertech 160' Powerstat
- Flexcool radiator hoses
- SLP MAFS
- One-piece aluminum driveshaft
- Z06 Clutch
- LS1 Master & Slave cylinders
- Pro 5.0 short-shifter
- Upgraded fuel delivery system (intended for SC use)
- Battery relocated & hidden
- Custom 2.5" Dual exhaust w/ cats & X-pipe (now I need headers!)
- Custom aluminum panels for the engine bay to cover up everything except the engine.
- Custom Fuel Rail covers (I'll be working on these soon)
Exterior:
- WHEEL UPGRADE!
-- before: stock puny 16x7.5 300zx wheels w/ 225/45/16 tires
-- After: 18x9 Y2K Cobra wheels (the ford lug pattern fits and the GM doesnt.. dont flame me for that! I really wanted Z06'ers)
-- 265/35/18 Nexen n3000 Y-rated tires on all 4 corners
- everything else same
Interior:
Custom Autometer gauge pod with:
- Speedo/Tach
- Oil/Water temps
- Fuel Pressure and Level
- A-pillar with Air/Fuel and another undecided gauge
- Everything else same
It will have all the extras too:
- Power steering
- Power windows
- Stereo
- Lights
- and A/C will come once I can afford a new system!
All this under the stock hood... besides the new wheels and gauges.. my car will look exactly how it did.. until you lift the hood!
Agenda for future mods:
- HEADS/CAM (long-tube headers if they fit!)
I'll keep updating the pics as I get more new ones!
-Vann
Old 09-23-2004, 12:42 PM
  #213
Scalpel's Avatar
{Combo} (2) LS1 M6
{Pics} (3) I've got some older ones up (non-completed) .. and I'll get the real stuff up in about 2 weeks
- The Z
- New Gauges
Completion date: September 24th 2004 (coming up!)
Engine/Performance:
- Custom cone-filter intake
- Relocated hood-latch to accomodate custom intake
- SLP MAFS
- Z06 Clutch
- Lightweight battery relocated to rear panels of trunk (hidden)
Exterior:
- WHEEL UPGRADE!
Interior:
- Speedo/Tach
- Oil/Water temps
- Everything else stock!
- Power steering
- Power windows
- Stereo
- Lights
I'll get pics and video posted on or just after September 24th, 2004! You'll all be among the first to see this creation living and breathing!
-Vann
Damn that is AWESOME!
Old 09-23-2004, 11:27 PM
  #214
5.7LImport's Avatar
That's gotta be the best compliment I've received so far! Thanks!
-Vann
Old 09-24-2004, 11:10 AM
  #215
rigi's Avatar
[QUOTE=Pro Stock John]Please list:
1) 1957 Chevrolet Bel Air
2) 1999 Camaro LS1/4L60E
3) http://home.rixtele.com/~rigi/project.htm
Richard
Old 09-29-2004, 07:37 PM
  #216
Cobra20's Avatar
Default 1979 Datsun 210
I am wanting to cram a LS1 and a T56 into my 1979 Datsun 210 Hatchback or my 1975 Datsun B210 Sedan. I am thinking the sedan because I can seal the trunk from the passenger compartment so I can add a fuel cell. Instead of going with a fuel tank at the rear of the car.
Old 10-04-2004, 01:50 PM
  #217
JAKDUPKUSTOMS's Avatar
Default my mess
1949 ford hardtop convertible
00 4.8l truck motor
custom made headers and motor mounts
it wont be the fastest thing in the world but itll be fun
Old 10-07-2004, 09:50 AM
  #218
Scott Purdy's Avatar
Default C1 conversion link not working
Can't find "Pictures of Interest" to look at your car. check the link I don't think it is working. I'm also building a C1 to C5 conversion Corvette, and would like to see some of the photos of your project.
Scott
Old 10-07-2004, 10:20 AM
  #219
Oscar Will's Avatar
Default 1935 Ford Tudor LS-1 powered
My 1935 Ford project started in 1998 with a Fatman frame and a junkyard LS-1 and 4L60E. It is now 75% complete
Fatman frame with Mustang II front suspension, a 9" Ford rear with four bars and coil overs
1998 LS-1 with GM "Hot Cam" kit, LS-6 intake, 1998 Y exhaust manifolds, GM perf. wiring harness and computer. Ho-made airbox. The new "low mass" LS-2 water pump (for clearance reasons mainly).
The rolling chassis is nearly complete and I should be sitting the body back on it within the next month so that I can complete the electrical and A/C
FYI....the new LS-2 pump is lighter and bolts on but when using F body accessory setup the pulley won't align, requires a little modification so the belt alignment is correct.
Old 10-08-2004, 11:59 PM
  #220
patrick_rodgers's Avatar
1957 Chevy Nomad with 2000 Camaro LS1 and 6 speed
Modified Camaro exhaust manifolds - air injection port on lower passenger side cut off for a-arm installation.
SnP wiring harness
Custom done VDO electronic speedo with check engine light included.
1986 Corvette Dana 44 rear end
Jim Meyer Racing rack and pinion steering kit with tubular a-arms and 12" disk brakes.
Quick Reply: Conversion folks please list your conversion in here
