Is mileage stored in the PCM or gauge cluster?
Old 10-31-2005, 09:25 PM
fastta's Avatar
Default Is mileage stored in the PCM or gauge cluster?
Does the 4th Gen gauge cluster have it's own memory and store mileage, or is mileage stored within the PCM?
Old 10-31-2005, 09:56 PM
Gary Z's Avatar
To prevent tampering and to allow replacement of instrument cluster, PCM or BCM, mileage is probably stored in two or three locations. I am not certain about the details but mileage is definitely preserved when the PCM is swapped.
Old 10-31-2005, 10:46 PM
kbracing96's Avatar
I know in the trucks, mileage is stored in the gauge cluster. I'm sure the cars are the sameway.
Old 10-31-2005, 10:50 PM
fastta's Avatar
So then I would imagine if you were to retain the original PCM, but swap clusters, the PCM would keep the actual car's orginal mileage and not that stored on the new cluster? Seem right?
Old 10-31-2005, 11:10 PM
Brains's Avatar
Its in the cluster. Swap clusters between vehicles, and the mileage moves with it.
Old 10-31-2005, 11:16 PM
99SS-T's Avatar
Score!!!! lol. Make sure to sticky this page in the forsale section. Alot of low milage cars will sprout up lol. GL
John
Old 10-31-2005, 11:23 PM
fastta's Avatar
John
That's why I was wondering why GM did not decide to store the mileage encrypted in a few different location such as the PCM and BCM.
I am selling a cluster and just wanted to know if the mileage on the car it came from was relevant.
Old 10-31-2005, 11:52 PM
Brandon Boomhauer's Avatar
but it can be found in trucks even if its swapped...
Old 11-01-2005, 10:58 AM
kbracing96's Avatar
Yep, the cluster will show the same mileage in the new car as it did in your car.
Old 11-01-2005, 12:06 PM
12secSS's Avatar
From what I recall, the ECM will keep the gauge cluster updated on the mileage. When the engine is shut off, the gauge cluster keeps that last mileage stored in memory. So when you swap a cluster from vehicle to vehicle it just accumulates mileage based on the last stored mileage counts given to it. You can have the gauge cluster reset to a different mileage reading (currently some dealers will only do this for new gauge clsuter ONLY!) or down to zero. Then it will start counting up again when it gets a proper signal from any ECM. The ECM does have a mileage counter that cannot be accessed, much like the runtime.
Old 11-01-2005, 03:25 PM
fastta's Avatar
Thanks for the replies guys.
Old 11-01-2005, 04:21 PM
zrater's Avatar
to the average person looking at the cluster they dont know ,till they scan it
then wtf >>>>>>>>>>>>>>>>>>>>>>>>
Old 03-25-2008, 12:53 PM
SSpdDmon's Avatar
Can someone validate this? I have a new-to-me cluster to go into my car, but don't want the other guy's mileage.
Old 03-25-2008, 01:29 PM
wait4me's Avatar
Car dependant, it is only stored in the Cluster. Some do store it in the BCM but not many. I think H3s and a few others..
Old 03-26-2008, 07:46 PM
poolshark021's Avatar
There is a shop called specmo that can reprogram the milage on a cluster for you. You have to sign a waiver or something but they will do it. There is one in flint, and I think one closer to you as well but I can't think of where right now.
Old 03-28-2008, 07:47 AM
SSpdDmon's Avatar
Thanks! They're two miles from where I work.
www.specmo.com
Old 05-28-2008, 12:32 AM
TexasSignature2002's Avatar
I know it stores mileage in the cluster, but im sure it stores it somewhere else so that you dont buy a car showing 10,000 miles when it realls has 189,000.Surely it is, im just not sure where.
Old 11-09-2013, 11:44 AM
LT4orbust's Avatar
Does anybody know if the mileage is on a chip in the cluster or in the lcd on a 97 firebird, I have a replacement cluster with 184,000 miles but my car only has 72,000 miles, I want to take the cluster apart and change the part that has the mileage over to the new cluster .
Old 11-09-2013, 12:18 PM
02BlkZ28's Avatar
I know my car has had the gauge cluster replaced. It has 90 thousand on it but thats not the actual mileage. It has way more than that. How would i get it back to the correct mileage?
Old 11-09-2013, 01:07 PM
LT4orbust's Avatar
I FOUND A NEW cluster circuit board for the "97 firebird only" on ebay and it looks like there is a chip that can possibly be pulled, it may be soldered in.... I'm taking mine apart to find out since nobody seems to know, I'll post what I find out
Quick Reply: Is mileage stored in the PCM or gauge cluster?
