which port on master cylinder goes to the rear brakes?
Old 09-04-2005, 03:55 PM
yody's Avatar
Default which port on master cylinder goes to the rear brakes?
I have C5 brakes and LS1 rear brakes on my 71 firebird. I also have a LS1 master cylinder, currently i have the port on the master cylinder closest to the firewall going to the rear brakes nad the port closest to the radiator going to the front, but recently I was informed this coudl be incorrect. Is this true? is the rear port for the front brakes? Also the brakes feel pretty good, I have hydroboost also. Could this cause a problem? obviously i will just redo the lines if it is wrong. Thanks!!
Old 09-05-2005, 01:56 PM
roy
roy's Avatar
Edited for erroneous info
Old 09-05-2005, 01:57 PM
yody's Avatar
yes an Fbody master cylinder
Old 09-05-2005, 02:55 PM
roy
roy's Avatar
edited for erroneous info
Old 09-10-2005, 12:58 AM
yody's Avatar
I just did some searches and it seems most people put their line locs in the rear port, meaning the rear port is for the front brakes, meaning mine is backwards, I am wondering though, if the master cylinder really cares front/rear? If it puts out the exact same pressure front and rear?
Old 09-10-2005, 01:08 AM
roy
roy's Avatar
Disregard my Post Man. I told you erroneous info . I got confused and edited it and it came up wrong. i am now deleting that stuff.
Youare correct the rear port (the one closest to the firewall) is for the front brakes.
Old 09-10-2005, 12:02 PM
yody's Avatar
do you know how the master works and if the way i have setup will be incorrect?
Quick Reply: which port on master cylinder goes to the rear brakes?
