Anyone else seen fatigue spalling on cam lobes??
Old 08-25-2005, 12:45 PM
bowtieman81's Avatar
Default Anyone else seen fatigue spalling on cam lobes??
Well, pulled the stock cam out of my engine last night and found what looks like some fatigue spalling on 2 of the lifter lobes. Anyone else seen this?
Is the stock camshaft cast? Good thing I am replacing it, and I am glad I ordered new lifters for it now
Attached Thumbnails Anyone else seen fatigue spalling on cam lobes??-lobe1.jpg   Anyone else seen fatigue spalling on cam lobes??-lobe2.jpg   Anyone else seen fatigue spalling on cam lobes??-lobe3.jpg
Old 08-25-2005, 07:07 PM
cowboysfan's Avatar
looks like alot of milage on that motor or lack of oil. check oil pressure or clogged passages to cam and associated parts. just trying to give u ideas to look at. hope this helps.
fuerzaws6
Old 08-25-2005, 07:39 PM
gollum's Avatar
I have seen a worse case one time in this forum with an aftermarket cam and high tension springs.
Old 08-25-2005, 10:15 PM
raven4960's Avatar
definetly a lack of oil...check your lifter retainers...kinda looks like the lifter got turned around in the bore and bit on the cam a bit.
Old 08-26-2005, 09:30 AM
Mileage on the engine is 48,000. The stock cam has about 35,000 miles (previous owner had a TR224 cam in it for a while). It does have isky 295 springs, which are pretty stiff. I think it's lack of oil. The previous owner said one time after a dyno run the oil pressure dropped to basically 0. He shut her off right away, but I think thats what caused this cam issue (and probably my cylinder scuffing ).
Anyway, a new ported oil pump is going in with the new cam and lifters.
Old 08-26-2005, 10:13 AM
GuitsBoy's Avatar
Ive seen a few other cases of this on the forum, but I dont recall any resolution as to how it actually happened. It looks very similar to the spalling on my rear axles when i changed my wheelbearings. My axle was never without oil, I figured the spalling may have been caused by small filings floating around after installing my 4.10s. In your case, maybe theres something floating arund your engine... might want to inspect your oil filter and check for filings.
Quick Reply: Anyone else seen fatigue spalling on cam lobes??
