Chevy Monza Swap in progress
Old 05-11-2005, 07:44 PM
Monza355's Avatar
Default Chevy Monza LS1 Swap in progress
I'm swapping a 1998 LS1 into my Monza 2+2. I'm wondering what would be the best wiring harness for this. I have the 98 computer and harness already. Is there a cheap aftermarket harness? I read Speartech is very good but $$$. Painless has a $499 harness but I was wondering if that is a plug & play harness? Is it pretty easy to wire in the stock harness? I'm using my built turbo 350 with 3000 stall and 3.73 gears. I just need the basics to get this running. I don't have to worry about emissions or anything like that.
Thanks,
Bill
Old 05-11-2005, 08:23 PM
hugger 6933's Avatar
Thanks,
Bill
spend the bucks and send it to john . you won't regret it . SPEARTECH he did what he said he would do when he said he would do it. you can't go wrong with using his services. jim
Old 05-12-2005, 08:12 PM
Monza355's Avatar
Thanks, that does sound like the best way to go. Can't wait to drop it in this weekend. Hopefully I'll have the engine bolted in waiting for fuel and electronics to get done.
Bill
Old 05-12-2005, 10:23 PM
Tydriver's Avatar
Pics or webpage of this swap ???
Sorta a soft subject for me as I had a 1980 Monza Spyder that had the 2.5L Iron Duke in it (Ugh...) Loved the car, but was a slow *** pig..
Sold it for an 86 Z24 and still regret it to this day.. x100
Old 05-13-2005, 05:28 PM
Monza355's Avatar
I have pics that I need to download and I'll have them up as soon as possible. The 2.5's are slugs, at least it was a Spyder! You should look at V8Monza. com. We have 1700 members and two big meets a year. There is a Vega going together in Norway with an LS1. He posts here as well.
Bill
Old 05-14-2005, 06:56 PM
Monza355's Avatar
Default Pics
Thanks,
Bill
Old 05-25-2005, 08:23 PM
Monza355's Avatar
I got the engine to sit in the car. The camaro oil pan needs a small section taken out of the middle step in the sump. I'm getting this welded locally. The engine plates I'm using put the V8monza.com motor mounts right in the factory location. The 98 Camaro exhaust manifolds look like they'll fit real well, it may be a little tight on the passengers side. I'm going to replace the stock in tank fuel pump with 255lph in-tank pump and 3/8 line and run a corvette filter/regulator. I'll post more pics when I down load them from my camara.
Bill
Old 05-25-2005, 09:08 PM
Frizzle Fry's Avatar
This guy (wait4me) is good with harnesses and tuning-> https://ls1tech.com/forums/conversions-swaps/324196-mail-order-pcm-tuner.html I'd change to 99+ ECM/Harness before it's too late though...
Old 05-25-2005, 09:29 PM
Phoenix 5.7's Avatar
if u are going to run factory ehxaust manifolds, id look at 01-02 fbody manifolds, they flow a lot better than the 98-00
Old 05-29-2005, 12:31 PM
donnyonee's Avatar
if you have the motor, pcm and harness, make it fit yourself. i put a 94 lt1 into a 88 944. changed the pcm location from the front left fender to the pass foot compartment. cut off what i didnt need and resized/relocated the rest. solder and heatshrink all the joints, worked fine.
Old 09-24-2005, 07:04 PM
Monza355's Avatar
My Monza is progressing very slowly. I need to get a 7" power brake booster to clear the coils on the drivers side. I'll have to fab up a new bracket for the power steering and I'm getting the S&P alternator bracket for the passenger side. I have to also get an O2 sensor bung welded in on the passenger side exhaust. I was at 3000 lbs with the iron headed 355 and me so I should be at 2700 with me after the swap and the other weight savings that I'm doing. I'll post pics soon.
Bill
Quick Reply: Chevy Monza Swap in progress
