Power steering pulley removal/replace?
Old 04-27-2005, 10:09 PM
JDebler's Avatar
Question Power steering pulley removal/replace?
Does anyone know the best way to remove and replace the power steering pulley on an LS1?
I am sure the answer is simply to use a puller, but where can I get one? Is that something I can rent at my local Autozone/Murrays etc? Do I need anything special? Any tips or tricks or anything I need to know?
I am swapping out the stock one for a Turn One pulley, if anyone is curious. Thanks in advance.
Old 04-27-2005, 10:45 PM
2xLS1's Avatar
http://www.autozone.com/servlet/UiBr...ing_pulley.jsp
Old 04-27-2005, 11:15 PM
JDebler's Avatar
Awesome, thanks.
That helps me get the pulley off, how do I putt the new pulley on? Never done this before.
Old 04-27-2005, 11:16 PM
2xLS1's Avatar
Same tool installs the stock pulley. Don't know about the fancy one you are putting on.
Old 04-27-2005, 11:23 PM
JDebler's Avatar
Killer, I assumed so but wanted to make sure.
It is the Turn One pulley, that can be seen here:
http://www.lingenfelter.com/Merchant...egory_Code=P11
Guys on the board here have bought it direct for cheaper. Kinda blingy, but better than the factory plastic one.
Thanks again!
Old 08-10-2005, 12:33 AM
LS1FIRE's Avatar
Does anyone know if the lingenfilter pulley is the same size as the stock one? The pulley seems heavier will this effect anything? Thanks
Old 08-01-2006, 05:55 PM
HAWKVERT's Avatar
I bought a Synister Motorsports billet aluminum pulley for my 2002 Firehawk but haven't installed it yet. I have been searching post to find out how to do this myself. Seems pretty staight forward but what about the radiator coolant tube? Don't you have to take this loose to gain access for pulley puller?
Old 08-01-2006, 07:27 PM
LS1FIRE's Avatar
I bought the pulley remover and installer from habor freight, the piece did not fit so good and i had to grind it a little to fit. Not sure if theres enough room to pull the pulley with the radiator in the way, i had the radiaitor out when i did mine.
Old 08-02-2006, 11:21 AM
Slammed99s10's Avatar
It is pretty straight forward, the coolant tube is a pain but you can push it down alittle. I rented the tool from AutoZone and installed mine in about an hour.
Quick Reply: Power steering pulley removal/replace?
