Does it matter which terminal you disconnect on the battery when working on the car?
Old 03-27-2005, 11:34 AM
JEspinoza's Avatar
Default Does it matter which terminal you disconnect on the battery when working on the car?
I am about to do some work on the car and should disconnect the battery. However, I hate disconnecting the negative terminal because I always end up touching the rachet with the positive terminal somehow and making sparks. So is there anything I can do to make this easier or can I just remove the positive terminal? How about put electric tape over the positive terminal so I don't touch it? I always get freaked out when touching the battery.
Jason
Old 03-27-2005, 11:55 AM
SloPony91's Avatar
I take both off when I work on my carand tuck them down behind away from everything
Old 03-27-2005, 04:57 PM
FrozenMonkey's Avatar
Just be careful and ALWAYS disconnect the POSITIVE terminal first. Keep the battery grounded (negative is ground). Try not to touch the positive wire on metal as it possibly could be holding some charge after you disconnect it. If you are completely **** about it, you could wrap some electrical tape around the connection. The rule of thumb while dealing with electronics is:
1. Connect NEGATIVE (-) first and then connect POSITIVE (+).
2. Disconnect POSITIVE (+) first and then disconnect NEGATIVE (-) if you need to.
Old 03-27-2005, 05:47 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
I disagree. There's a better chance of grounding the positive to something else than there is with the negative. After all, usually the only thing near the negative terminal is the positive terminal. With the positive terminal you've got virtually everything else (including yourself if you're against a metal part).
IMHO.
Old 03-27-2005, 06:12 PM
98boxer's Avatar
You're joking right?
Old 03-27-2005, 06:15 PM
98boxer's Avatar
Jason
Check your auto parts stores, because I have heard of a connection that you add to the battery terminals and this devise will allow by the turn of a switch to shut the battery off - summit, jegs, should have something too.
Old 03-27-2005, 06:51 PM
00Z28 Camaro's Avatar
Dont ever use your battery to lay wrenches on ( dont flame) you probably know this ,I found out the hard way. Funny as **** tho
Old 03-27-2005, 07:01 PM
2kt/a's Avatar
I was wiring a plow one night at work at about 11:pm(after 16 hours). really tired. I hooked the + to the battery, then went to hook it to the plow solenoid. I accidently hit the fender. I love battery welding!
Old 03-27-2005, 07:04 PM
Dal1as's Avatar
Always disconnect your ground first and reconnect it last. NOT your positive.
Edited. (Reconnect the ground last)
Old 03-27-2005, 08:49 PM
slow's Avatar
I have always heard.
Disconect the Ground First, and Reconnect the Ground LAST
This makes the most sense as far as accidental arcing is concerned.
Ryan
Old 03-27-2005, 10:26 PM
glennhl's Avatar
Always disconnect the ground first and connect it last. That way you don't risk shorting the wrench to ground when working on the positive. That's one of the first things you learn, sometimes the HARD way!
Old 03-27-2005, 10:35 PM
Pontiacerator
RevGTO's Avatar
Originally Posted by slow
I have always heard. Disconect the Ground First, and Reconnect the Ground LAST. This makes the most sense as far as accidental arcing is concerned. Ryan
This is what I've always heard and done. But someone knowledgeable was telling me the opposite recently. Could it be different for PCM/electronics cars? I can't think of a reason why ...
Old 03-27-2005, 10:40 PM
FBDYLVR's Avatar
Removing: Negative first, then Positive
Installing: Positive first, then Negative
Old 03-27-2005, 11:23 PM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
when I am working on the car I remove the negative.
Old 03-28-2005, 01:06 AM
Zymosis's Avatar
Remove the ground.
Old 03-28-2005, 08:39 AM
Squintz Palladoris's Avatar
But it make such a nice shelf! Especially top post batteries
Quick Reply: Does it matter which terminal you disconnect on the battery when working on the car?
