Smog Pump Delete on a 94 Formula
Old 12-14-2004, 03:19 PM
WhiteSSP's Avatar
Default Smog Pump Delete on a 94 Formula
What is required to delete the smog pump/EGR system from my LT1? The EGR valve is already gone with the vac hoses plugged and the block off plate, but everything else is still on the car. I want more space in my engine bay.
Old 12-15-2004, 09:47 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
unbolt it from the front of the block, been a long time since idid mine but like 3 or 4 bolts, unplug it and done. i know there is a lin somewhere? it has been years since i did this mod.
not hard though!
Old 12-16-2004, 02:03 PM
Mikey 97Z M6's Avatar
Thumbs up
Yup, there is a metal tube/line that goes from the pump, underneath the timing chain cover to the passenger side header. Unless you have the accessory bracket off the car, you'll be cutting that metal tube to get it off because of the way it winds through everything. Then just plug the holes in your headers and tune the PCM for the EGR deletion so you don't get a SES light. Done.
Mike
Quick Reply: Smog Pump Delete on a 94 Formula
