ls1 weight
Old 11-24-2004, 11:04 AM
zamboxl's Avatar
Default ls1 weight
anybody knows how much an ls1 engine weights with the intake and the water pump on, with no oil in it.????
Old 11-24-2004, 11:54 AM
thunderstruck's Avatar
its right at 400 pounds
Old 11-24-2004, 12:21 PM
msbz_ls1's Avatar
with oil in it i think it weights 385 lbs.
Old 11-24-2004, 12:30 PM
zamboxl's Avatar
wow thast alot lighter than i though, i was thinking it was like 600 pounds or something.
Old 11-25-2004, 02:06 AM
Slammed-am's Avatar
While on the subject, does anybody know how much an lt1 weighs?
Old 11-25-2004, 02:24 PM
zamboxl's Avatar
probably around the same but iam not sure, prob some one else will chip in an answer
Old 11-25-2004, 03:01 PM
tim99ws6's Avatar
doubtful, cause a Lt1 car is a Iron block. I'd bet around the 500lb range....
Old 11-25-2004, 03:32 PM
BigPlanTransAm's Avatar
well, an iron LS1 weighs about 80lbs more than an alum one. and the most of the internals of an ls1 are designed to be lightweight so i would say 500lbs for an lt1 is probably not far off
Old 11-26-2004, 02:15 PM
MiamiDave's Avatar
Old 11-26-2004, 07:21 PM
coop5885's Avatar
LS1 is 430 lbs. Read it in hot rod about 3 days ago.
Old 11-26-2004, 08:57 PM
Tiger2o69's Avatar
If that all the weight they saved making it aluminum wouldnt it have been better to just put a stronger block in.
Old 11-26-2004, 09:27 PM
tim99ws6's Avatar
why isnt a LS1 a strong block? Harlan is making over 1000 at the wheels on the "weak" LS1 block.....
Old 11-26-2004, 09:36 PM
Deranged Rat Fink
badjuju342's Avatar
The LS1 has 6 bolt mains and likes higher RPMs than LT1s . The also use steel sleeves in the cylinders. The LS1 is definitely superior to a LT1. Lighter weight , lower height ,and no Optispark are among a few of it's advantages.
Old 11-27-2004, 10:29 AM
Tiger2o69's Avatar
Thats damn good but i have always seen on there that they are not that strong.
Old 11-27-2004, 04:19 PM
SRC
SRC's Avatar
whats that in kilogrammes
Old 07-22-2007, 11:01 PM
1LoudTA's Avatar
divide by 2.2
Old 04-04-2008, 05:05 PM
LS1IMPULSE's Avatar
They can handle some serious abuse. In stock form LS1's can handle near 500WHP NA or upwards of 550WHP and 8PSI with FI. Aftermarket internals raise those numbers greatly and with a girdle and pined billet maincaps the LS1 blocks can handle some serious power 1000WHP+ (more than most will ever need or use)
80LB's is a pretty big chunk of weight in the front of a car, it would definetely be a noticable change.
Old 04-04-2008, 10:34 PM
the_merv's Avatar
I used to have a LT1..I swapped to LSX and preferred to keep that Iron Block for the durability.. that and just to say I still have an Iron Block with a 4" Bore..
Old 04-05-2008, 06:14 AM
landonew's Avatar
Damn, 3250 race weight with the iron block. That car was on a serious diet.
Old 04-05-2008, 07:02 AM
slowjoe99's Avatar
Hold while I steal the thread...
What are some of the first things that should be dont to reduce the weight of an f body?
Quick Reply: ls1 weight
