Titanium Valves
Old 10-17-2004, 09:28 AM
PREDATOR-Z's Avatar
Default Titanium Valves
Who sells them , and what brands of Ti valves are available on the market.
Old 10-17-2004, 10:00 AM
BTL FED's Avatar
I know rev makes titanium valves, but I believe you also have to run a special seat, I know TEA made a set of Ls1 heads with titanium valves
Old 10-17-2004, 10:06 AM
Ben R's Avatar
Ferrea will make you a set of Ti valves.
Old 10-17-2004, 11:58 AM
TD's z's Avatar
Victory
Old 10-17-2004, 12:03 PM
cyphur's Avatar
whats the benefit of titanium valves? other then beiing lightweight and strong as ****. i would presume they are somewhat pricey, no? is there some special added benefit i am missing or is it the obvious ones i listed?
Old 10-17-2004, 01:00 PM
DrkPhx's Avatar
You're right; they are stronger and lighter than regular valves, but their high price isn't usually enough to outweight the benefits to most. If they came down in price, more would using them.
Old 10-17-2004, 01:39 PM
Suspended Sponsor Account
ForceFed HP's Avatar
Ti valves are expensive and are considered a race only valve, they are subject to heat cycling so have a short life span, also you must use a beryllium seat as a standard seats hardness can damage a Ti valve.
they are lighter so absorb/use less energy to move but are not good for street use
Old 10-17-2004, 02:01 PM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default Titanium valves
There are several manufacturers of titanium valves a couple already mentioned - Rev and Ferrea. Also, Del West, Manley, Brodix, and Xceldyne. Xceldyne is sold only through CV Products to the best of my knowledge. Any of the sponsors, myself included can purchase from the above companies.
Titanium has a density about 60% that of steel. Therefore an exact duplicate of a steel valve in titanium will weigh 60% of what the steel valve weighs. Anything you can do to reduce the weight of the valve, spring, retainer, locks will help keep the valve train stable (out of valve float) at high revs.
Titanium is used in racing engines only. It is a poor bearing material in that it tends to gall up. The valve stems are usually plasma moly coated to keep them free in the guides. Connecting rods have the big end sides coated to keep the rods from welding themselves together.
Titanium needs a soft valve seat - beryllium copper to keep the valve from wearing away. Even then a lot of guys are now coating the valves with a DLC coating to make them more wear resistant.
Titanium valves are a lot more expensive than steel but are a necessity for most racing applications.
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 10-17-2004, 07:00 PM
AdamSS's Avatar
Sooo....how much do these cost ?
Old 10-17-2004, 07:54 PM
Ben R's Avatar
Too much to justify using them in a regular street motor.
Old 10-17-2004, 08:10 PM
I can shift faster than you.
Jason99T/A's Avatar
They are ~$100 per valve.
Old 10-18-2004, 11:25 AM
2001CamaroGuy's Avatar
.......nice......$1600 for a full set of Ti Valves or $200 for a full set of Ferrea valves......hmmmm.....
Old 10-18-2004, 01:40 PM
PREDATOR-Z's Avatar
Thanks, this would not be for Street application but for a high reving stroker.
Just observing the possibilities.
Old 10-18-2004, 04:39 PM
xxxhp's Avatar
How much power gain would they provide over regular valves?
Old 10-18-2004, 04:56 PM
itchygomey98's Avatar
It's not just a straight forward power gain you would get by using them. If you have valve float, there are 3 ways you can fix it -
1. Don't rev it that high
2. increase spring tension
3. lighten the valve/retainer/rocker tip
If you have a setup that wants to make more power and rev higher but can't because of float, this is what you would do. For 1600 bucks, I'd make a different cam choice, cuz it just isn't worth the dinero for most of the people at our level.
Quick Reply: Titanium Valves
