Drag Racing Tech
at what Horsepower level do yu pull the front tires up off the ground
Old 08-16-2004, 07:58 PM
cgworth's Avatar
Default at what Horsepower level do yu pull the front tires up off the ground
at what Horsepower level do yu pull the front tires up off the ground and what level do you get them up 6 feet on a launch
Old 08-16-2004, 08:12 PM
jrp
SN95 Director
jrp's Avatar
its not about hp; proper suspension setup, weight reduction, and traction are the main factors.
Old 08-16-2004, 08:14 PM
cgworth's Avatar
so what type of setup produces this
Old 08-16-2004, 08:17 PM
jrp
SN95 Director
jrp's Avatar
check with the Drag guys.
Old 08-16-2004, 08:18 PM
jrp
SN95 Director
jrp's Avatar
or just search
https://ls1tech.com/forums/showthrea...ting+front+end
Old 08-16-2004, 08:20 PM
Jason98Zee's Avatar
You need pretty much a full drag setup to pull the tires 6feet. its all about hooking up and weight reduction, ie, rapid motorsports video on their homepage of the red T/A
And 99% of the time ppl pull the wheels off the ground more than a few inches, they dont mean to, it hurts your E.T. and it can be very costly. if you come down to hard you can smash the oil pan and lose all your oil, and bye bye engine.
Old 08-17-2004, 05:34 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
yep, wheelies looks cool but are wasted motion unless it is moving the car forward as well as up. Most try and set-up for the line between big wheelie and hooking to move the car downtrack. Drag-style shocks and as previously mentioned set-up suspension can make a 12 second car pull the wheels, but you have to have everything right! The more hp/torque you make, the easier it is
Derek
Old 08-17-2004, 06:12 PM
AdioSS's Avatar
I've been told that my 4200# bolt-ons LT1 powered 96 impala SS has yanked the left front tire a few times. It's not making much power (the motor is stock from the throttle body to the exhaust manifolds) but with the mods that I've done, it gets plenty of torque to the ground. 3200 Vigilante converter, 4.10 gears, strong posi, sticky tires and track, no swaybars, QA1 shocks, etc. The best I've dyno'd was 255hp/320tq to the wheels.
Old 08-17-2004, 06:27 PM
Raped-Ape's Avatar
im guessing my car is making somewhere in the high 400 range, mine pulls the front left up about 6 inches when it hooks (TTII 17x9.5 w/275/40/17)
Old 08-17-2004, 07:04 PM
LTLHOMER's Avatar
6 feet is quite the accomplishment. But seriously...I've pulled the wheels cutting the lawn with a John Deere. Reverse, slam it to forward and HOLD THE HELL ON! All about weight transfer.
Old 08-17-2004, 07:07 PM
cgworth's Avatar
LMAO
Old 08-17-2004, 08:06 PM
WILWAXU's Avatar
All it took for my Formula was a set of ET Streets and a Yank TP-4400
Car pulled a wheel with ~1200 miles on the OD
Old 08-17-2004, 09:30 PM
JNorris's Avatar
LMAO
I tried but my 17HP 42" cut Murray would not do it. I am thinking about some weight reduction on the front end....Maybe a light weight K-member and some skinnies!
Old 08-20-2004, 10:15 AM
mike c.'s Avatar
my car made 388hp(tuned down for nos use) on amustang dyno and i pull the tires about 5in off the ground(stock ws6 tires,not front runners)
Old 08-20-2004, 12:37 PM
JZ'sTA's Avatar
I have a 72" liquid cooled 22 HP mower, and that thing will almost flip you over. It pulls the wheels from a dead stop without reverse to foward.
Fun ****.
Old 08-20-2004, 01:39 PM
CAMAROBOY69's Avatar
I have just a little over 400hp in my 69 Camaro and when I put the 10.5" slicks on my car I was shocked when my friends said i pulled both front tires off the ground about 2". If it wasnt for the camcorder I would have never believed it. That was when it was set up for drag racing. Now it is set up more for Pro-Touring so a wheelie now would be a lot harder since I dropped the car close to 4" lower that it was.
Old 08-20-2004, 03:01 PM
STF Veteran
99-LS1-SS's Avatar
I would be sweeping up transmission and rear end pieces if I got my car to hook up enough to pull the front tires. It will happen one day.
Old 08-20-2004, 03:03 PM
After my 4th or 5th hard launch with the slicks I blew out the 4 speed Borg Warner. That was just inspiration to install the 6 Speed T-56.
Quick Reply: at what Horsepower level do yu pull the front tires up off the ground
