Cylinder Wall scratch
Old 08-10-2004, 12:07 PM
CrimeSScene's Avatar
Default Cylinder Wall scratch
How much honing would it take to get out a cylinder wall scratch, just deep enough to hang a fingernail on? I have a 99 block and rotating assembly, but two cylinder walls have scratches that are straight up and down the wall, the length of the piston travel. I'm hoping to have just a small amount of honing done, and use the .25mm oversized rings that GM put out. Is this possible, or am I looking at new pistons too?
Old 08-11-2004, 12:28 AM
soundengineer's Avatar
you wont know until the machine shop tells you how much they had to hone it to fix it....
very possible you will need a custom piston set if you can hang a nail on the scratches...
Old 08-11-2004, 08:13 AM
Plan B's Avatar
As soundengineer, just said... I'd get it measured first... It may work out fine.
Old 08-11-2004, 08:22 AM
J-Rod's Avatar
I have to agree. Anything big enough to hang a nail, or be aware of to the touch of most folks is bad...
Dang Peter, what are you still doing up. Isn't it past your bedtime ...
Old 08-11-2004, 08:38 AM
Plan B's Avatar
11:30pm here... Just winding down after a big day at the office. Sam's office...
The little drive home an hour ago, with 670rwhp has kinda got my blood pumpin.
Old 08-11-2004, 02:35 PM
Thanks for the replys, I'm really hoping I can sqeak by with the stock pistons. Don't have the dough to replace them right now. Guess I'll just have to wait and see.
Old 08-11-2004, 03:18 PM
6 Second Club Moderator
LASTLS1's Avatar
Don't worry about it. Unless your doing a big rebuild, don't sweat it. Run a hone and call it a day.
Old 08-12-2004, 07:57 AM
OK, yeah just doing a stock rebuild with a small cam. Just got my hands on the parts cheap and figured I'd build a standby motor in case I screw mine up.
Quick Reply: Cylinder Wall scratch
