Brand new air ratchet won't work
Old 06-17-2004, 10:15 PM
theblur98ss's Avatar
Default Brand new air ratchet won't work
I just got a craftsman air compressor and it came with some tools. I hooked up the ratchet and it worked for a minute or so and now it won't work. It just shoots the air out by the handle. I put some oil down in it and it just sprays it out. Is the ratchet bad or did I do something wrong?
Old 06-18-2004, 07:33 AM
robertbartsch's Avatar
It is busted from the factory - Craftsmutt strike again - hand tools, sockets and hand wrenches are guarnateed forever - I'm not sure about air wrenches, however....Since you just bought it they should replace it, however.....
Old 06-18-2004, 08:30 AM
jimmyblue's Avatar
Might check for a little thumbwheel on the butt
that sets torque; make sure it isn't in a funny
position, try setting it to "11" etc.
Old 06-18-2004, 10:29 AM
hawgs's Avatar
Hit the top of it on the ground and it will loosen it up. Sometimes there is a part in the middle that goes back and forth that can get stuck. Hit on the concrete a couple times and it will loosen up... I have had it happen to me a couple times.
Old 06-18-2004, 03:00 PM
BTL FED's Avatar
Mine did the same thing, I just hit it on the ground and it works
Old 06-30-2004, 12:11 AM
Mike K.'s Avatar
A quick hit on the ground and I bet it works again.
Quick Reply: Brand new air ratchet won't work
