[B]The BLUE valve springs that came with the GM Hot Cam......[/B]
Old 06-07-2004, 07:11 AM
Tommy Tucker's Avatar
Question [B]The BLUE valve springs that came with the GM Hot Cam......[/B]
...are supposed to be from the 2001 LS6 and will be able to handle the 0.525" lift. Will they be able to handle the 0.556" lift when I install my Crane 1.8 R/R?? (I already have them so don't tell me I shouldn't buy them. )
Did the 2001 LS6 have smaller lift than the 2002?
Presumably the 2002 LS6 springs will work well.
If you happen to know if the GM ASA cam will work with these R/R without needing cut-outs I'd be glad to hear one way or another (I'm guessing maybe not).
It's not a daily driver.
Cheers
Old 06-07-2004, 10:31 AM
Colonel's Avatar
The '02 LS6 cam had more lift. Without looking it up (SEARCH BUTTON) I believe it was about ~.550 compared to ~.525 for the earlier LS6 cam. I was told that the late model LS6 springs are good for as much as about ~.580.
Old 06-07-2004, 10:52 AM
Thanks Mr.C
Any idea about the ASA duration clearence issues with the 1.8's? Is it a crap idea?
Tom.
Old 06-07-2004, 11:23 AM
Colonel's Avatar
Sorry, I don't know much about the ASA cam. Maybe someone else will chime in.
Old 06-07-2004, 05:37 PM
mcflyz28's Avatar
it has the same lift as the hot cam, do yourself a favor and put in better springs to start with that way cam swaps will be just that cam swaps and not cam and springs which are a PITA.the lift on the ASA cam is .525
Old 06-07-2004, 05:54 PM
ss rally red's Avatar
I agree go ahead and at least install comp 918's, so when the new cam bug hits you it will be a 3/4 hr job max.
Old 06-07-2004, 07:50 PM
jd13's Avatar
DO NOT INSTALL THE LS6 SPRINGS!
Get some 918s.
Trust me.
I know...from experience.
Old 06-07-2004, 07:54 PM
jd13's Avatar
Oops, sorry. I read the wrong lift. Yes, the later model ls6 springs will work with the .556 lift, but like said, do yourself a favor and get some real springs.
Colonel, I'll guarentee you ls6 springs aren't good up to .580 lift because I found out the wrong way.
Old 06-08-2004, 03:43 AM
Thanks for that guys.
So assuming the 0.556 lift for the ASA cam as well (with 1.8's) would the 226/236 duration fit without problems?
Quick Reply: [B]The BLUE valve springs that came with the GM Hot Cam......[/B]
