Can PCV issues lead to low oil pressure?
Old 05-28-2004, 06:50 AM
Scalpel's Avatar
Default Can PCV issues lead to low oil pressure?
I have a Metco breather on the oil fill location, LS6 valley cover and the AMW catch can.
I have noticed some low oil pressure at idle and was curious if PCV configurations can have an affect on oil pressure.
Thanks.
Old 05-28-2004, 08:19 AM
DARK AGE 53's Avatar
Out of those mods I would reinstall the stock oil cap and see what happens, this might sound stupid but could your oil need changing.
Al
Old 05-28-2004, 08:55 AM
John_D.'s Avatar
Originally Posted by CANNIBAL
...curious if PCV configurations can have an affect on oil pressure.
The more vacuum in the crankcase, the lower the oil pressure. PCV shouldn't significantly affect it. With crankcase evac systems it's a consideration.
Old 05-28-2004, 09:39 AM
JS
JS's Avatar
I saw the exact same thing.
I took the catch can off my car and my oil psi shot up 4lbs.
John,what causes too much vacum in the crankcase?
How can u eliminate it,breathers?
Old 05-28-2004, 10:16 AM
John_D.'s Avatar
Ideally you want a little vacuum in there. The pcv normally does this. If you remove the pcv, and use a breather, then any pressure that builds up just goes out through the breather. You never see any vacuum then, if the pcv is removed. But you may get some blowby and oil coming out of the breather and getting on the engine or firewall.
The reason it affects the oil pressure, is because the oil is constantly escaping out of the bearings. If you had 40psi of oil pressure at regular atmospheric pressure inside the engine, for example, and then somehow you could pressurize the inside of the engine to 40psi, theoretically the oil couldn't get out because the pressures would be equal, with the air pressure trying to hold the oil back. But the oil pump would still be pumping, so the oil pressure would continue to build up until the oil started getting out again. And if you have a vacuum in the engine, it is trying to suck the oil right out of the bearings, so the oil pressure is less in that case.
The old rule of thumb for oil pressure was 10psi per 1000 rpms, to protect the bearings. I don't know if that rule bends a little for the LS1 engine or not... As long as your oil pressure is within factory specs, I'd say don't worry about it varying with or without the pcv connected.
(a plus of having a little vacuum in the crankcase, is less resistance seen by the backside of the pistons, and a little less air friction seen by the crank) At 4" away from crank centerline, when turning 6000 rpms, things are moving at over 209 feet per second, or 143 mph....
Old 05-28-2004, 11:16 AM
JS
JS's Avatar
John,I have my valve covers tee'd and one pcv valve in the stock location working for both valve covers.Do u think it would benefit me to elimenate one side of my pcv and adding a breather to that cover?
Some people dont like running a breather and a pcv together.
Whats your take?
Old 05-28-2004, 11:47 AM
2001CamaroGuy's Avatar
if you go with a breather you need to remove the entire PCV otherwise you will get unmetered air (air that didn't go through the MAF) into the intake manifold and this will cause issues with your tune.
Old 05-28-2004, 11:59 AM
JS
JS's Avatar
Thats what I thought too...
Do u like running breathers or pcv camaro guy.
Old 05-28-2004, 12:05 PM
I would rather have a breather and no PCV as it prevents any oil from getting into the intake system. I had to run a PCV on my old engine because it had some cracked pistons (had to keep it driving till summer/class was out) but I will run a breather on my 388 for the above reason.
The only time the breather sucks is if you have lots of blowby because the oil will smoke and come out the breather and billow out under the hood (ask me how I know this... ).
Old 05-28-2004, 12:53 PM
JS
JS's Avatar
I have a new motor that was built correctly.I had file fit rings and a good hone done to the engine,I think beathers are better for my application too.
I might try it tomorrow and see how it works...
Old 05-28-2004, 01:11 PM
I would.....if everything is right with your pistons/bores/rings, you shouldn't have that much crank case pressure with either
Old 05-28-2004, 02:04 PM
JS
JS's Avatar
I have less than 3% leakdown in every hole...
Quick Reply: Can PCV issues lead to low oil pressure?
