Turbonetics 7875 Dyno Results
Old 11-14-2013, 06:05 PM
LT1RAY's Avatar
Default Turbonetics 7875 Dyno Results
My setup:
126k LS1 stock short block
Huron Speed kit
Turbonetics 7875 .96 a/r
317 heads
1218 pac springs
Pro comp head studs
LS9 head gaskets
Stock cam
Brain Tooley lifters
7.375 PR's
60lb Siemens
Racetronix fuel setup
91 octane
Full 3" exhaust to a Hooker Maxflow muffler
First pull had wheel spin
Second pull
I have around 4-5000 miles on this setup and had a few set backs this summer that kept me from the dyno (4l80 swaps and oil leaks). I had the car running great but I decided to take it to Clint at AIR for some fine tuning. Super happy with the results.
Old 11-14-2013, 06:22 PM
sbcgenII's Avatar
Nice numbers! Was that with a t56 or 4l80? What intake manifold?
chevellepowered's Avatar
awesome ! i just got a comp 7879 , i kno diff turbos but those numbers look promising .. congrats ..
Old 11-14-2013, 06:25 PM
LT1RAY's Avatar
T56 and a LS6 intake.
Old 11-14-2013, 06:29 PM
sbcgenII's Avatar
Strong numbers. Do you plan on going to the track?
Old 11-14-2013, 06:30 PM
STEEPSS's Avatar
Stock cam, and only 10#! Nice numbers!
Old 11-14-2013, 06:33 PM
totalchaos's Avatar
Nice numbers. How much boost? Hoping I can hit those numbers with my build.
Old 11-14-2013, 06:34 PM
thendawg's Avatar
That power curve looks great. Numbers are very impressive for 10psi! What cam are you using? Cant wait to get my 7875 build together!
totalchaos's Avatar
seen 10#. how does the turbo spool?
Old 11-14-2013, 06:59 PM
HUGGER ORANGE SS's Avatar
Ray, I'll try and get the video up and running for you. Thanks again for your business, very nice car.
Clint
Old 11-14-2013, 10:30 PM
S13LSx's Avatar
Put a cam in it and 20lbs. then youll see fast.
Old 11-14-2013, 10:57 PM
LS1Tech Sponsor
Superman09's Avatar
Very nice results Ray, glad you are enjoying it!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 11-15-2013, 01:32 PM
crispytoast's Avatar
I am very impressed. That car is very street able
Old 11-15-2013, 05:52 PM
LT1RAY's Avatar
Maybe next spring.
Thanks! I have a Datsun 280 that I'm about to stick a 5.3 and powerglide in.
Stock 99 LS1 cam, 202/210 472/479 117 LSA.
Boost is on the bottom part of the dyno sheet. It makes full boost by about 2900-3000rpm on the street.
Clint
Thanks Clint!
Cool.
Thanks Jon! Clint shot some sick video footage, hopefully I can post it tomorrow.
Thanks Jesse, this thing drives super nice. And still spins at the top of 3rd
Old 11-15-2013, 10:28 PM
02LS1ram's Avatar
Very nice number for 10psi! I keep having little set backs myself with trying to get to the dyno. Im at about 15psi with my 7675. The Huron kits are def a nice piece
Old 11-16-2013, 12:09 PM
1999Black_Z28's Avatar
Nice numbers Ray! I am curious to see your trap speed at this boost level so I can see how much I would gain with the 7875 over my TC78. I trapped 129 at the end of this year around 10.5 psi.
Old 11-16-2013, 10:09 PM
LT1RAY's Avatar
Thanks Dave! I'm curious as well, Jon trapped 126 with a slipping trans on 11lbs.
Old 11-16-2013, 10:38 PM
kelsey_canard's Avatar
x70189237401928347 nice numbers for the boost level! How much timing are you running? Any meth?
Old 11-16-2013, 11:44 PM
LT1RAY's Avatar
15* at peak torque, 16* at peak horse power. No meth.
Old 11-17-2013, 09:19 AM
totalchaos's Avatar
read your build thread and 1999BLACK Z28 build thread. was hoping both you posted results. wanted to see some numbers between a tc78 and 7875.
Quick Reply: Turbonetics 7875 Dyno Results
