How far will a 7675 go on a 6.0?
Old 10-28-2013, 06:53 PM
tiznodd's Avatar
Default How far will a 7675 go on a 6.0?
I have a late model stock LQ4 that I'd like to run to the edge and am thinking the CEA 7675 I have might not get me into the 800+ range through a 4l80. Just curious how much further I would get with this turbo setup on a 5.3 instead. I really don't want to change to another turbo since it's packaged tight and I don't want to cut everything apart. If I went with the 5.3, it would be an L33 so I would get the added bonus of 80lbs off the nose.
Also, any input on what the out of boost torque difference will be between a 6.0 and a 5.3? I know LS1NOVA made the switch, perhaps he would be willing to chime in? I am using a stock converter, so it will likely be more noticeable than most setups. This is a 90% street, 5% drag race and 5% auto-X deal. Running E85.
Old 10-28-2013, 07:16 PM
9 Second Truck Club
stock48's Avatar
It should get you there long as you don't go overboard on the cam. Too much cam will kill it. They will make enough to go 160 mph at ~ 3000 lbs.
Old 10-28-2013, 07:30 PM
tiznodd's Avatar
Meaning my current LQ4 will get me there? Is the TU1 (225/225) too much cam? What spooked me was seeing your S475 poop out at 16psi. It's somewhat similar to the 7675 from what I can tell. That's what had me thinking the 5.3 would be a better match.
Old 10-28-2013, 07:38 PM
9 Second Truck Club
stock48's Avatar
I ment the lq4 and 76/75. The cam might get some reversion but I would
Try it first.
My S475 would make over 20 psi but car didn't pick up any in the 1/8 past 17 psi. I did find the turbine all chewed up from pieces from my flex joint that blew apart prior to track outting. I have since repaired turbo and it is on truck pulling hard to 18 psi.
Old 10-28-2013, 07:43 PM
Man-Crush Warning
Shownomercy's Avatar
Mine just did 733ft/lb on 10psi.
Old 10-28-2013, 07:55 PM
Anti_Venom99's Avatar
I would also like to know! My setup will be done soon and I am a stock bottom LS2 with 317 heads, a 228/228 .588/.588 114 turbo cam, and the PT7675 CEA, on e85. I also have a 6 speed. I am hoping for 800whp... no idea what my torque will be lol
But it should be done in December so we will see!
Old 10-28-2013, 08:19 PM
jrpimp00's Avatar
Mine made just under 700 on 12 psi with a 224R 114lsa
Old 10-28-2013, 08:38 PM
tiznodd's Avatar
It looks like you've got a bigger exhaust housing on your Turbonetics. I'm concerned the .96 I have will hit a wall sooner than I'm hoping for. They do great in the mid-boost range.
I want to make sure my #3500 setup can run mid-140 mph at the track.
Thanks everyone for the input so far.
Old 10-28-2013, 08:41 PM
tiznodd's Avatar
Try it first.
How much less do you think the S475 is making than the GT76 you were running? If I recall, you were making 900 on a Dynojet with the Garrett.
Old 10-28-2013, 09:28 PM
9 Second Truck Club
stock48's Avatar
Im not sure but the GT76 definitely made more power. I think truck will go bottom 10's maybe scrape a 9.9 in mid 130's with the S475. Gt76 was 900 unlocked sae numbers. Was like 936 locked iirc.
Old 10-28-2013, 09:43 PM
Krenz's Avatar
Default pt7875 gts
I got a ws6 lq9 402 hci rear mount pt7875 .96 ar. On 14 psi made 700whp 723wtq max power at 5300rpm max torque 4700rpm only revving to 6100rpm cuz backpreasure becomes an issue from what I see after 14psi with a 7675 or 7875 on a 402,408. I was down to 630ish whp at 6500 rpm and at 6100rpm where I shift I'm still around 670whp so your rpm work range is lower rpm which for a dd 700whp ws6 is amazing. Tons of torque very quick but still I plan to switch to bw s475 with 96mn turbine 88mm exit on turbine with 1.32 t6 with a quick spool valve. Full boost comes around 3500rpm with my setup now with pt7875 gts. n should be 3000rpm or less with the bw and qsv
Old 10-28-2013, 10:32 PM
You have way to big of a motor to be running a 76 man... An s480 is where you need to go
Old 10-29-2013, 07:46 AM
RedRocketZ28's Avatar
The turbo would definitely be more efficient on the 5.3 but will work nicely on the 6.0. I have a similar setup, LQ4, TU1, 7875, 4L80e, E85. I ran 9.9 @ 140 with a 3400-3500 race weight on 14 psi. Trapped 142 on 16 psi and when tried to go to 18-19 psi the charge pipe blew off. I imagine it would have gone 144-145 on that pass. Dyno shows power dropping off around 5700 rpm, but screams all the way there. I think a cam change would help it pull harder up top.
The turbo doesn't really like being pushed that hard on the LQ4 though. I don't think 800 rwhp will be possible with it through a 4L80e. On 16 psi I made 677 rwhp. The Precision units do seem to make more power than the new Turbonetics units however.
I am making the switch to a S480 and have a feeling I will be kicking myself later. My current setup is a blast to drive on the street. I guess we will see what happens in the spring.
Old 10-29-2013, 08:14 AM
Krenz's Avatar
Default turbo
I know right!!!! I want an s480 with 96mm turbine and quick spool valve so bad!!!! Lol gonna be a winter project this year. Current setup is a blast on the street and I purchased the car built like this. Works good but can be improved for sure
Old 10-29-2013, 08:52 AM
willizm's Avatar
I'm pushing about 15psi and made 735whp and 920wtq on a mustang dyno unlocked converter. I ran out of injector or we would have pushed it harder. Forged ls1, tu1 cam, 317 heads, 9.5:1 cr, e85, proYank converter, 4l80e, pt7675. I only ran it on spring pressure(10psi) and went 10.4@135mph. Car was breaking up on higher boost passes so had to switch out plugs. All is right as rain so hoping to get some 9's next time out.
FWIW i'm happy with this turbo and will push it to the max once I up my fueling this winter.
Old 10-29-2013, 01:04 PM
7 Second Club
NicD's Avatar
Closest comparison I can make is my 5.7L with a 76GTS which is similar although the 7675 with a billet wheel will have a bit of an advantage but the turbine is still the choke point. My combo is done at 800 rwhp through a TH400 and more cubes will knock that down just a bit. I would run the 6.0L vs the 5.3L hands down given your 90% street with a stock converter application.
Old 10-29-2013, 01:40 PM
Mrmooney's Avatar
I'm making 700wrhp through a 5.3 th400 7675 and its having backpressure issues, I'm going to try swapping out cam as I believe for my combo it's not right, but 7675 on a 6.0 I think would be too small and you would have even more backpressure issues.
I am also at a much higher elevation of 5600+ feet above sea level so that could be it also.
Old 10-29-2013, 01:46 PM
denmah's Avatar
you see the guy with the notch mustang and a built 5.3 (347 cubes) going approx 8.5 @ 160+ with a 7675?
about that far hahah
Old 10-29-2013, 03:39 PM
tiznodd's Avatar
Lol. It seems everyone with a fox is running 8's these days. I've got a 3500lb pig to push down the track. No doubt that car is making some serious power though.
The responses seem mixed. If I come across a good deal on an L33 I'll go that route, otherwise I'll just use the LQ4 I've got.
Old 10-29-2013, 03:43 PM
tiznodd's Avatar
Yeah, the stock converter thing is something the 6.0 has going for it. The 5.3 might suck out of boost. As of now I can at least break the tires loose from a stop without spooling it on the brakes.
Quick Reply: How far will a 7675 go on a 6.0?
