AEM wideband ?
Old 09-08-2013, 06:21 PM
2000 TA owner's Avatar
Default AEM wideband ?
where does the blue wire go I have the white wire to my EGR do I need the 9 pin plug like the directions say a little confusing the way they instruct it seems like they give directions for there EMS but how do I wire it to a 2000 ta I did go out and buy a 9 pin to USB cable do I solder the blue wire to the #2 pin and ground to #5 and just plug it in to my laptop I have read the stickies but knowone seems to say where that wire goes they say wire to the PCM do they really mean PC. I have all the pids set up just need to get data to the laptop(HP tuner) any help would be greatly appreciated
Old 09-08-2013, 08:16 PM
MontecarloDrag's Avatar
Blue wire on AEM widebands is for serial data, HPTuners doesn't have serial wideband input so you need only the white wire.
If you have a standard interface, EGR is the way to go. If you have a pro interface you need to pulg it directly to pin #1 on HPT interface.
Old 09-08-2013, 10:07 PM
ok then why would it be I get no signal to hp [PID.2811]/.5+10 and all that shows up on my table display is 10 does this mean I am not getting the signal from the white wire to the scanner and if so what could it be
Old 09-08-2013, 10:09 PM
Do you have a pro interface?
Old 09-08-2013, 10:18 PM
no is there any way to test the signal going in should there be voltage in the white wire and or coming out of the brown egr wire
Old 09-09-2013, 06:45 PM
got it all setup thanks to gm forum
Old 09-10-2013, 09:10 AM
RENE'S RAGE's Avatar
So how did you wire it up?
I need to wire mine up.
Old 09-10-2013, 03:32 PM
http://www.gmforum.com/tuner-139/set...-tuner-278833/ This gives you step by step PIDs Histos andeverything needed with pictures great help for me being that Im old school worked the very first time just had to adjust my voltage a little for it to match my gauge I went from 10 to 9.8 Hope this will help you like it helped me
Old 09-10-2013, 04:31 PM
Thanks, I'm old school too. 55 yrs old.
Really just need to know where to hook up the white wire.
I'm guessing to the EGR pin in the PCM. But which EGR pin or wire.
I think there's 5 wires that go to the EGR.
I'll let tuner do the rest.
Old 09-17-2013, 06:35 PM
Monte4ever's Avatar
Pin 55 blue connector.
Old 09-17-2013, 06:46 PM
Monte4ever's Avatar
How did you check to make sure your voltage was right? I left mine at 10 and it seems right but I've seen a few change it form 10 to 9.78 - 9.80. How far off was it?
Quick Reply: AEM wideband ?
