Why would rear blinker flash but not the front?
Old 05-26-2013, 02:14 PM
Mr Phil's Avatar
Question Why would rear blinker flash but not the front?
I just replaced the housing and blinker socket and bulbs (3457a) and when I turn the lights on the bulbs light up but when I turn on the blinker either left or right or turn on hazards the rears will flash but the fronts will not. Any reason why it would do this?
Old 05-26-2013, 05:37 PM
Mr Phil's Avatar
Or if thisis the wrong section can u tell me which section to post it in
Old 05-26-2013, 05:50 PM
SS67SS's Avatar
You should check your blinker fluid level
Old 05-26-2013, 06:08 PM
Mr Phil's Avatar
Really? Does anyone with any intelligence have an opinion?
Old 05-26-2013, 08:16 PM
AmnSF's Avatar
Check all the relay's? Fuses? Try disconnecting the battery to reset everything? May or not be the fix but just spitting out options..
Old 05-26-2013, 09:45 PM
Mr Phil's Avatar
hazard and blinker relay under the dash are both the same correct? Ill check everything tomorrow but I really don't understand this car. More problems keep coming up before I can spend money to upgrade I keep having to repair lol
Old 05-26-2013, 09:57 PM
AmnSF's Avatar
I don't know if everything is the same, I've never had any electrical issues like that (knock on wood). I don't know how everything is wired and have basic knowledge from classes I took in high school lol. Could even have a short in the wiring as well.. Plenty of options. Hoping somebody with more knowledge will chime in and confirm any of the sources I gave you.
Old 05-26-2013, 10:28 PM
Mr Phil's Avatar
Yea anything electrical I'm lost in most cars, I just don't have the patience for that **** lol
Old 05-27-2013, 04:24 AM
CopMagnet's Avatar
So you replaced the DRL socket? There are 2 wires to it. Could it be possible that you may have reversed the connection of those wires? Did you connect them well? I suspect the wires are reversed. When I did mine I kept this in mind before removing the old one.
Old 05-27-2013, 04:57 AM
Mr Phil's Avatar
Well I color coded the wires (I used an oem used socket I bought off ebay) but just in case do u have a picture of the wires? And my parking lights work when lights are turned on but no drl or blinker
Old 05-27-2013, 05:58 AM
lemons12's Avatar
....That was my first response on FB. LOL
Old 05-27-2013, 01:35 PM
Mr Phil's Avatar
And btw I have 3 wires coming out of my socket
Old 05-27-2013, 03:28 PM
CopMagnet's Avatar
It's been a year, perhaps there were 3. Since I soldered them I swear I remembered 2. Anyways, glob some die-electric grease in there so it doesn't fry like the old one. So you're sure each socket wire is matched up to the others. Can you do an electrical test on each wire to ensure all 3 are getting power? At some point in this leg there is a short or faulty component. If you don't have a meter there's always the Harbor Frieght 10 dollar special.
Old 05-27-2013, 04:36 PM
Mr Phil's Avatar
Well I went and used a test light, the the ground (black wire) has nothing coming to it, the drl wire gets power when lights are on, and the blinker wire gets nothing when blinker is turned on. I color matched the wires Brown with brown, black with black and blue with blue. I even tried switching Brown with blue and blue with brown and all that did was light up the drl brighter but still no blinker. And I just went and bought another Flasher from autozone part number EL12. So I know its not the Flasher.... Does anyone have color coded wire diagram of the blinkers? I'm at a loss here
Old 05-27-2013, 04:49 PM
Mr Phil's Avatar
ok i just found this on another site... he said he DRL module was fried, where is this located at?? and does a 98 even have DRL? lol
http://www.ls1.com/forums/f6/problem...ignals-142071/
Old 05-27-2013, 05:07 PM
lemons12's Avatar
Blinker fluid is low or out.
Old 05-27-2013, 05:08 PM
lemons12's Avatar
Black is the ground...
DRL-daytime running lights... And yes, that is what you are having issues with. No clue where it is located.
Old 05-27-2013, 05:37 PM
Mr Phil's Avatar
Evan.... I swear to god I hate you so ******* much right now lol
I found drl module after I ripped halfmy dash apart and I found this, thankfully I have soder still from fixing the radio/windows in the bcm so maybe this will fix it, if not then oh well its not like it got any worse lol
Old 05-27-2013, 05:55 PM
lemons12's Avatar
Actually, it could.
O man.. Sometimes I make myself laugh so hard my side hurts.
That feel.
Old 05-27-2013, 06:04 PM
Mr Phil's Avatar
**** u sir
well it fixed it, but now of course another problem has came up... the driver side blinker does not blink nor does the DRL work, and the hazards do not work in the rear but it works up front in the passenger side (i never use me hazards but just throwing it out there to help whoever actually knows anything and doesnt keep saying blinker fluid)
.... the parking lights come on when i turn the lights on but thats it.... im thinking hoping since i didnt replace that socket only the passenger side socket that its just corroded and needs to be replaced, they sell the socket at my autozone so ill try that tomorrow... in the mean time, i have a semi victory
Quick Reply: Why would rear blinker flash but not the front?
