how do I hook up my alternator wires ???
Old 05-25-2013, 06:58 PM
jaywill's Avatar
Default how do I hook up my alternator wires ???
To the alternator on my 5.3 ??? I know where the battery 1 goes to ...but what wire frim my plug in.."79 makibu'
Old 05-25-2013, 07:35 PM
ls1nova71's Avatar
Depends on year of engine. But if you're staying EFI, and ots an 04 or older, the wires go to the PCM and yoy don't have to do anything to them.
Old 05-25-2013, 10:43 PM
jaywill's Avatar
04..w/carb..alt. is off a 04 surburban
Old 05-26-2013, 05:44 PM
jaywill's Avatar
What wire do I hook to the 04 alternator the brown wire or the red wire from this plug
Old 05-27-2013, 07:03 PM
downset71's Avatar
The red is just basically battery +. The brown is just the dummy light to dash warning light. Does your LS alternator have 3 wires on plug? On mine the white also had to goto bat +
Old 05-27-2013, 09:07 PM
jaywill's Avatar
I did not get a plug with my alternator... how can I tell which plug do I need ???
Old 05-27-2013, 11:16 PM
1981TA's Avatar
hope this helps. This is for a car NOT using a factory ECM/ EFI system.
Old 05-28-2013, 03:40 AM
jaywill's Avatar
THANKS but...my plug do not have a white wire just a red and a brown..and the big red 1 that goes to the post on the badk of the ALT...
Old 05-28-2013, 12:06 PM
jaywill's Avatar
the guy i got it from said it was a 3-wire...
Old 05-28-2013, 03:47 PM
downset71's Avatar
U should really googles some pics of F-body, truck style, corvette , etc alternators cause alot of them use different plug shapes. After u determine what style alternator u actually have u can figure out which pins to use. Post a pic!
Old 06-29-2013, 11:19 PM
jaywill's Avatar
I have a 4-pin plug which pins do I need to use ?
Old 07-02-2013, 07:11 AM
1981TA's Avatar
As Downset71 said, post a pic of your alternator. My pic shows clearly which pin on a corvette alternator needs to be connected, and how. I'm going to guess that your connections won't be very different, but ya never know.
Old 07-02-2013, 05:40 PM
jaywill's Avatar
will do...
Old 07-03-2013, 08:25 PM
jaywill's Avatar
Old 07-20-2013, 01:57 PM
jaywill's Avatar
I hooked the brown idiot light wire up to the L pin on the alternator. now when i turn ignition switch voltmeter starts to move like it going to read..i dont have a belt on the car yet... by it starting to read do that tell its hooked up right ???
Quick Reply: how do I hook up my alternator wires ???
