T56 & LS1 - which pilot bearing
Old 03-20-2013, 06:08 AM
the1theycallthe1's Avatar
Default T56 & LS1 - which pilot bearing
I'm getting confused - which pilot bearing do i need?
I keep seeing two different kinds, one that's like a sealed bearing & the other that's like a needle roller bearing.
Any ideas please?
Old 03-20-2013, 07:33 AM
garys 68's Avatar
The corvette LS7 and CTS use a larger OD bearing that seats in the outer flange of the crank, 12557583
The 98-02 F body and GTO uses the smaller OD bearing that rides in the inner flange, 14061685
Old 03-20-2013, 07:47 AM
calhoon's Avatar
NAPA carries the smaller bearing as B657....what you want with a LS1/T56 combo.
Old 03-20-2013, 10:58 AM
Thanks Chaps - its a 4.8 LR4, will that make a difference to which one i need?
Old 03-20-2013, 01:31 PM
garys 68's Avatar
As long as you're using an f body T56, LS1 flywheel and clutch, the smaller one will work.
Old 03-20-2013, 01:39 PM
Thnks Gary - it's a GTO/Monaro box.
Old 03-20-2013, 03:17 PM
SNLPerformance's Avatar
We have the bearing you need in stock. You need the needle type. If you have a problem finding one, just let me know.
Old 03-20-2013, 03:28 PM
Thanks Steve - I hope you ship to England! I'll be in touch.
Old 05-20-2013, 06:33 AM
atli126's Avatar
What bearing do I need with a 5.3 with ls7 clutch and flywheel with a 2000 Camaro? We have already broke the bellhousing twice and can't get it on. We have the pilot bearing still in from the t5 I was using before.
Old 05-20-2013, 07:43 AM
garys 68's Avatar
If you had a T5 behind a 5.3, that had the LS7 bearing that sits in the outer crank flange. If you're switching to an f body T56, you'll need the 98-02 f body bearing that seats in the inner crank flange.
Old 06-06-2013, 12:14 PM
maroonls1z's Avatar
Isnt there bell housing spacers avaliable so that you can use the LS7 type bearing in a f-body? what would be the benifit of one over the other? I am trying to make the decission on which one i want to use right now
Old 06-06-2013, 05:24 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Why on earth would you want to run a spacer just to use a different (incorrect) bearing? Just run the small LS1 bearing and be done with it.
Andrew
Old 06-07-2013, 05:29 AM
garys 68's Avatar
The spacers are generally used to run an LS T56 on a earlier gen BBC/SBC. A pilot bearing is about $12, spacer over $100. Pretty easy choice.
Quick Reply: T56 & LS1 - which pilot bearing
