direct injection = more horsepower ?
Old 01-22-2013, 04:28 PM
AAK z28's Avatar
Default direct injection = more horsepower ?
does direct injection create more horsepower or is it just a more efficient way of getting fuel into the engine?
Old 01-23-2013, 07:46 AM
Kleeborp the Moderator™
MeentSS02's Avatar
By itself, I don't think so, but it allows you to raise the compression ratio, and also lowers emissions.
Old 01-23-2013, 12:15 PM
Blackpanther99's Avatar
I always had that exact same question. I always heard people saying the direct injection equals more HP. Is it because of the higher compression ratio that lets you gain more HP?
Old 01-23-2013, 05:08 PM
pferris's Avatar
di lets you run higher compression do to lower temps. Higher compression gives you more tq and that is more hp.
Old 01-23-2013, 06:30 PM
AAK z28's Avatar
im not an engineer but lookin at the new 6.2 model at the autoshow it looks fairly simple for a cylinder head company to take a set of heads and design them for direct injection on gen 3 and gen 4 motors. but then that would also require redigning fuel rails, injectors, and an intake manifold. probably not worth it
Old 01-25-2013, 10:44 AM
Agreed^ doing DI makes you start changing stuff around for the same reason. Labor for all that is also more expensive.
Old 01-25-2013, 01:32 PM
MeentSS02's Avatar
I think this is one of those situations where if you car didn't come with DI straight from the factory, it would probably be cost prohibitive to do a conversion, and for not very much gain at the end of the day.
Old 01-25-2013, 06:27 PM
AAK z28's Avatar
agreed^
Quick Reply: direct injection = more horsepower ?
