cloyes single roller vs Rollmaster double?
Old 01-01-2013, 05:41 PM
javier1730's Avatar
Default cloyes single roller vs Rollmaster double?
Im doing the Heads and cam on my camaro, and i have two timing sets. One is a Cloyes hex-a-just single roller, and the other one is a Rollmaster double roller. Which one do you guys recommend using. The motor will be turning ~7k and around 650-700hp on the spray. thanks
Old 01-01-2013, 06:42 PM
Blackpanther99's Avatar
Rollmaster double roller will be better at that HP.
Old 01-01-2013, 07:24 PM
bluethunder364's Avatar
I agree.....Rollmaster, my motor makes around 490 and I use the single version with the factory chain guide and it has performed great! It's nice stuff.
Old 01-01-2013, 08:15 PM
javier1730's Avatar
The problem with the rollmaster is that its a double roller and i hear i might run into problems with pick up tube alingment
Old 01-01-2013, 10:14 PM
Super Hulk Smash
JakeFusion's Avatar
That's because you'll have to run spacers. If you grind the oil pump, you won't have to use the spacers (and you'll probably have to grind either way). The only way around the grinding is I think the Synergy ported LS6 and SLP pump. Both are pre-clearanced for double rollers.
Old 01-02-2013, 01:40 AM
RonSSNova's Avatar
What does the HP level have to do with single or double roller chain?
The Cloyes Hex Adjust uses an IWIS chain, very good stuff. It also forces you to degree the cam, which is a good idea.
Ron
Old 01-02-2013, 07:55 AM
LS1Tech Sponsor
Slowhawk's Avatar
I'm ussualy a fan of C5R single chains. Don't know for sure what the single roller you listed usses for a chain.
My motor is at 1k rwhp so far and we run a single no problem to 7400rpm and heavy springs.
Old 01-02-2013, 08:16 AM
Super Hulk Smash
JakeFusion's Avatar
Cloyes has two levels of chain... the LS2 and the C5-R. If it's over $250, it's the C5-R. Cloyes charges like $110 for their sprockets/gears.
The Rollmaster, if the Gold Series, has a pre-stretcched IWIS chain and nitrited gears (both crank and cam). So it's a damn fine piece for the price ~ $135.
Old 01-02-2013, 12:28 PM
javier1730's Avatar
can the cloyes hex-a-just be set up using dot-to-dot?..im pretty sure my set has an IWIS chain.
Old 01-02-2013, 02:21 PM
Super Hulk Smash
JakeFusion's Avatar
Yeah... but just degree the cam. Especially if it's Comp. The grind is probably off from the cam card. Degreeing will take that mystery off the table...
Old 01-02-2013, 03:13 PM
javier1730's Avatar
I have never degree a cam before. Do you know of a good write up about it, and a good cam degree kit? thanks also, can i degree the cam with the block in the car? thanks
Old 01-03-2013, 02:49 PM
Super Hulk Smash
JakeFusion's Avatar
Comp actually has detailed instructions (no pictures tho):
http://www.compcams.com/Technical/In.../Files/145.pdf
And they have a degree wheel kit. It's expensive, though. I don't know if it's worth it to buy just for one cam install.
But you can install it dot to dot with both of those timing sets.
Old 01-03-2013, 04:49 PM
RonSSNova's Avatar
With the Cloyes Hex Adjust, you are taking a risk as to whether or not it is actually set to 0 when it says 0 on the adjustment.
Although mine came out right on w/o tweaking it. Lucky maybe?
I chose the Cloyes true roller becauseI have used them in the past on my rat motor stuff. It is good quality and the chain isn't sloppy like the LS2 chain is.
Perhaps they make a non-adjustable true roller single chain set? I'm not sure, but you can check.
Ron
Quick Reply: cloyes single roller vs Rollmaster double?
