mechanical oil pressure guage
Old 11-17-2012, 07:55 PM
LsxNotchy's Avatar
Default mechanical oil pressure guage
where do i put my mechanical oil pressure guage and water temp??
Old 11-17-2012, 08:22 PM
JOHNNY59's Avatar
can put a tee in the block before the stock oil sender. it will let you use both gauges. water temp goes in the side of either head.
Old 11-17-2012, 08:34 PM
LsxNotchy's Avatar
im sorry i should have been more specific.. carbed 5.3 in a foxbody
Old 11-17-2012, 09:00 PM
JOHNNY59's Avatar
would be the same place as the 5.7L as the 5.3L is a truck motor.
Old 11-17-2012, 09:09 PM
LsxNotchy's Avatar
oh ok i understand what your saying now.. is there anyway i can remove the stock sender completely and just run the line directly to where the sender used to be?
Old 11-17-2012, 09:22 PM
JOHNNY59's Avatar
sure can as long as you have the correct fitting. I just like to keep the stock gauge working.also the stock sender/gauge may be use to cut power to the fuel pump if the motor lost oil pressure,but not 100% sure.
Old 11-17-2012, 09:25 PM
LsxNotchy's Avatar
my harness dont have a plug for the oil sender so i gotta do it this way i guess.. thanks man
JOHNNY59's Avatar
on the LS1 5.7 motor there is a port above the oil filter that can be tapped into for oil pressure
Old 11-17-2012, 10:44 PM
Ferocity02's Avatar
The port above the oil filter, tap it for 1/8 NPT. This is where my turbo oil feed is, but also works for a pressure sensor
Old 11-17-2012, 11:42 PM
badazz81z28's Avatar
Save your self the trouble. Use the existing tapped ports. Auto-meter sells adapter fittings.
Old 11-18-2012, 01:30 AM
wildcamaro's Avatar
Autometer sell an adapter piece that goes from the stock oil sender at rear of intake and adapts it to the standard fitting size to run a mechanical oil gauge.
Old 11-18-2012, 08:12 AM
LsxNotchy's Avatar
ok cool thanks guys! what about my water temp sensor? the fittin on the sensor is too big for the holes in the head
Old 11-18-2012, 12:03 PM
Same thing....Auto-meter sells an adapter for the water temp hole in the head too.
I suggest staying away from mechanical gauges. They make such a mess if the lines ever get kinked/melted/broken
Old 11-18-2012, 12:13 PM
99camaroSS1521's Avatar
answered my questions good thread
Old 11-20-2012, 02:48 AM
chrisfrost's Avatar
Autozone sells a copper line kit 4 like $10 4 mechanical oil pressure gauge ,,,,it includes 2 or 3 brass adapters such as 1/8 npt ,,,,,,,,I would just drill and tap the adaptor above the oil filter ,,,,,,,it's the most accurate location that tells You the pressure going to the mains and rod bearings and leave the other 1 as well .
Quick Reply: mechanical oil pressure guage
