4l80 Reverse Delay
Old 11-17-2012, 05:59 PM
shield's Avatar
Default 4l80 Reverse Delay
I have a three or four second delay when I engage reverse on my manual valve body 4l80. I have been told that this is due to the stall converter?
Is that factual?
Old 11-19-2012, 08:51 AM
Blackpanther99's Avatar
What Stall do you have? stock 4l80e converter?
Old 11-19-2012, 03:43 PM
maddoglou454's Avatar
If it is the converter it should also delay in forward. Sounds like the typical 4L80E, problem, it's usually the boost valve sticking or a worn-out reverse servo pin.
Old 11-19-2012, 03:58 PM
3.8redbird's Avatar
Will these cause something to break down the road?
Old 11-19-2012, 04:20 PM
After I posted on the thread. I noticed you said full manual valve body and depending on whose it is some of them do have a delay in reverse and never have any issues. Not saying that it is in the valve body. But of course, if you wanted to find out for sure, you could replace it with a factory valve body. Of course, that's easy for me to say. I have valve bodies everywhere we do it for a living. It's your call, If it has good positive shifts at wide-open throttle, you're probably okay. If it is a TCI , I would not trust it drive it around, but stay local. We have used their products for many years, good stuff but for whatever reason on their 4L80E valve bodys they have some more research to do.
Quick Reply: 4l80 Reverse Delay
