Hoses from water pump
Old 11-04-2012, 02:38 PM
ShaggyLT1's Avatar
Default Hoses from water pump
Ok guys. 1995 Formula LT1 M6. I bought the car from a buddy of mine. He had the car for 17 years. He replaced the water pump at some point. I was under the car doing some other work and noticed 2 hoses coming out of the bottom of the water pump. The one on the driver side comes down to the radiator. Not sure where the other one goes but it turns upward. They look pretty shabby. They have hose clamps on them. The one on the driver side is seeping a bit. Where can I get these hoses? Part numbers? Names?
Old 11-04-2012, 04:47 PM
96capricemgr's Avatar
I would look at a full kit. I am sure you have more options than I did on my Caprice but I used the Goodyear HiMiler kit and other than being an ugly bright blue I am really happy and they replaced every coolant hose. On the b-bodies there are a couple hard plastic pieces a flow restrictor to the heater core and a t-connector for the surge tank look at what you have and go ahead and replace that stuff too.
Old 11-04-2012, 04:59 PM
ShaggyLT1's Avatar
Thanks for the reply. I hope to hear from some camaro/firebird guys on this too.
Old 11-04-2012, 06:17 PM
Village Troll
SS RRR's Avatar
You can always take them into a parts store and match them. Any parts store should at least have the main upper and lower hoses pre-bent.
Old 11-04-2012, 07:12 PM
02v8ta's Avatar
That second hose you speak of should go to the heater core IIRC. The red arrows pictured here? http://shbox.com/1/heater_hoses.jpg sounds like what you're describing.
I also believe you hit one of the factory metal crimps if you follow the hose to replace it. Just make sure both ends have a simple hose clamp, if not you have to cut the crimp. I'm not positive on that one though.
Take if off and just go match it at a parts store like SS suggested.
Old 11-04-2012, 07:15 PM
02v8ta's Avatar
OP depending on what your coolant and rest of the cooling system look like condition wise, this isn't a bad idea at all.
Old 11-04-2012, 07:45 PM
SilverSS07's Avatar
The hose on the bottom going to the pass side goes to the heater core as in the diagram linked above. The one going to the radiator I had to get at NAPA. Sorry I don't remember the name of the hose but you need to get that specific hose. It isn't a common size (metric I think) and the ends are different sizes. It will leak if you get regular heater hoses for it.
Old 11-05-2012, 07:23 AM
My take on this is that if some of the hoses are potentially original they are going to be near failing anyway. Why dump coolant 3 times to do the hoses piecemeal?
Plus when I bought the kit price for hoses was pretty reasonable compared to purechasing one at a time.
Old 11-05-2012, 05:07 PM
ShaggyLT1's Avatar
Yeah I'm definately gonna replace them all. I was just looking at the kits. They are available in black but summit only has the blue. Blue is actually my favorite color but not under the hood on a green car. Yuk!! Anyhow I'm looking around for a supplier with the black ones.
Old 11-05-2012, 07:03 PM
94FBIRD's Avatar
I just did the blue Goodyear kit from Summit. I checked at Napa and two of those pre-bent heater hoses were $29.99 EACH. To buy all the hoses I needed at Napa would've cost $30.00 more than the Goodyear kit.
Old 11-05-2012, 08:44 PM
02v8ta's Avatar
Last I knew only the blue kit was available and they fade pretty bad, talk about looking like puke under the hood with a green body
Old 11-06-2012, 06:59 AM
There are companies that make silicon replacement hoses Samco comes to mind, might have a larger color selection.
Old 11-07-2012, 08:41 AM
lt1needingboost's Avatar
jegs also has a 4 pc replacement package for like 100 in BLACK ive had them on for 2 yrs no problems. just something to think abt. comes w all clamps as well .
Old 11-07-2012, 09:09 AM
pillarpod's Avatar
good year blue hose kit turns puke green over time
Quick Reply: Hoses from water pump
