Best streetable cam for LS6 05 V?
Old 10-18-2012, 05:55 PM
chitown21y's Avatar
Default Best streetable cam for LS6 05 V?
I know this has probably been beaten to death but I though I would get a recent idea of what the best cam is for my V. On a small budget but will be installing myself.
On a scale 0-10 I am looking for a 7-8 as far as lope. This is my daily driver so I want some more power but not much more vibration at idle. Also the best kit to upgrade the valve train?
Thanks, Dave
Old 10-18-2012, 06:24 PM
heavymetals's Avatar
I use the Comp Cams #1500 system for the valve train.
You cannot use the stock pushrod with this and you need a shorter one.
Old 10-18-2012, 08:13 PM
DMM
DMM's Avatar
I would talk to Geoff at EPS (Engine Power Systems)...Geoff is the one that made Thunder Racing what is once was. Ed Curtis is another that comes to mind. Another excellent cam resource is PredatorZ (Mark) on the forums here...he can really point you in the right direction and confirm that the spec's you have been given will meet your desires.
If your cam ends up being over .600" lift...you will be told to get the Comp Cam's trunion upgrade for your OE rockers...the rockers themselves are stout pieces other than the needle bearings that puke over .600" lift.
Also, the person that specs the cam will also be able to tell you the pushrod length (always measure when putting it together though) and what springs you will need. I wouldn't change the lifters unless there is a problem with them...although some of the OE lifters have gone bad after a stout cam has been installed...but there is no duplication of labor here since the cam stays in the block and the heads have to come off for lifter replacement.
Your probably going to get everyone shouting at you to use Pat G...while he is very good at what he does...a cam in an otherwise stock LS6 has been done thousands of times over.
My guess is that you would be happy with a standard tried and true 228/228 on 114*...pretty sure you will end up getting something close to that.
Old 10-18-2012, 09:31 PM
itsslow98's Avatar
EPS 230/238 on a 112 with the springs he recommends.
Old 10-19-2012, 10:54 AM
chitown21y's Avatar
I am interested in this cam. What kind of power is possible with just the cam and some valve train upgrades? I also have a lead for some harland sharp rockers for 200 they worth it?
Old 10-24-2012, 03:47 AM
mystic98ls1's Avatar
Best streetable cam I have ever used is a howards cam 226/232 577/588 on a 115. I even used it in a bolt on 2010ss and the car made 452rwhp.. Prob put this cam in 15 cars. also can easily use single springs.
Old 10-24-2012, 04:30 AM
CTS-V Shifter Sales
07CTS-V's Avatar
My LS2 made 400/400 on a mustang with this cam, p&p 243's and B&B headers/exhaust. It pulled hard and the lope was awesome.
http://www.summitracing.com/parts/CCA-54-444-11/
Old 10-24-2012, 04:35 AM
itsslow98's Avatar
My guess is around 405-410. I wouldnt do harland sharp.
Old 10-24-2012, 06:01 AM
Bowtie70SS's Avatar
Is the stock LS6 cam .550 lift 117lsa 204/218 ?
Old 10-24-2012, 09:05 AM
DACTARI's Avatar
Agreed. PredatorZ is the man.
Old 10-24-2012, 10:59 AM
chitown21y's Avatar
Any video's of this cam?
Old 10-24-2012, 02:43 PM
CTS-V Shifter Sales
07CTS-V's Avatar
Quick Reply: Best streetable cam for LS6 05 V?
