Can i run a 250 shot??STOCK MOTOR!
Old 06-18-2002, 12:40 AM
TravWS6's Avatar
Default Can i run a 250 shot??STOCK MOTOR!
would i be able to run a 250 shot on my almost stock TA.. i wouldn't use it alot.. but would it be way to hard on the motor? if i go with nitrous over the super charger i wana be able to gain more power thro it.. i don't think nitruos would be worth it for a 100 shot or less.. like they say GO BIG OR GO HOME! so help me out here..Thanx
Old 06-18-2002, 12:46 AM
SSU Moderator
RyanJ's Avatar
Default Re: Can i run a 250 shot??STOCK MOTOR!
more like GO BIG AND WALK HOME.
all kidding aside. a 250 shot is more than id want in my plastic intake, much less on my glass bottom end.
Old 06-18-2002, 02:56 AM
Andy West's Avatar
TravWS6,
I sincerely think anything more than a 150 shot (wet or dry) is a bad idea on a stock motor. If you supercharge your engine anything over 6 psi, you should drop your Compression Ratio. Somewhere around 9.1:1 is usually what the big boys run with 12-15 psi blowers.The stock LS1 is 10.1:1 CR I believe. Your average 6 psi blower should give you a 150 HP increase.
Like I said, if you go much more than 6 psi, personally I would lower the CR.
If you run more than a 150 HP Shot of N20 I would upgrade you internals. Both a blower and N02 puts alot of pressure on the crank and mains.
For instance I am currently having built a 383 LT4. I has 4 bolt Splayn Caps,Lunati 4340 Forged Steel Crank,Rod, and Pistons,etc. I plan on a 200 Wet Shot. Would I try such a thing on a stock LT1 or LS1? My answer is NO!
I hope this helps, I would hate to see you blow such a beautiful and costly motor.
Good Luck <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 06-18-2002, 09:59 PM
Back in the staging lane
Beeler422's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TravWS6:
<strong>would i be able to run a 250 shot on my almost stock TA.. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah......once. <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old 06-18-2002, 10:23 PM
TravWS6's Avatar
ya i noticed it aint a good idea eh.. i guess a 150 shot would be plenty right.. **** i might not even do nitruos.. i cant make up my mind!...thanx guys
Old 06-20-2002, 12:24 AM
rich's Avatar
I just smoked #6 piston with a 175 shot.Two stage nx kit fuel system beefed up and the fp gauge didn't drop below 55 psi. Burnt the tip off and now has wrisy pin knock. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old 06-20-2002, 06:32 AM
Slart's Avatar
Rich,
At what RPM did your 175 engage?
- Steve
Old 06-29-2002, 05:22 AM
RAGENZ28's Avatar
I RAN A 350 SHOT AND DRAGGED MY BUMPER, NO WAY IN HELL I'D PUT 250 IN A STOCK LS1, 150 IS TOP SAFE LEVEL I THINK , I PREFER 2 STAGE DRY KITS ON F-BODIES 50 IN 1ST 75 MORE IN 2ND WORKS GREAT ON RADIALS
Old 07-04-2002, 12:29 AM
tbyrne's Avatar
A 250 shot would be a quick death for a stock LS1 motor. I'd be hesitant to use a wet shot over 150 without doing some upgrades. NOS doesn't really recommend using more than a 100 shot with this dry kit.
Andy: The 6# LS1 and LT1 superchargers will usually show a 100-110hp gain while the 8-9# kits will produce about 140-150hp. The LS1 motor can easily take 9-10# of boost. The compression should be lowered for anything higher than that. I run 17# with the ATI F1 kit on an LS1. That motor has 8.9:1 compression.
Tom
Old 07-04-2002, 01:26 AM
Dave's Avatar
sssssssssssssssssssssBANG!flopflopflop............ .. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old 07-04-2002, 02:00 AM
Bad Habit Bird's Avatar
If you are wanting the whole "Go big or go home" thing going for you just do a two stage wet kit on the car. You could get a sweet direct port setup for less than a blower setup and still have the same "ahhh" factor as a blower <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 07-04-2002, 02:11 AM
BigBlue's Avatar
One word: KABOOOOOOOOOOOM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
Old 07-05-2002, 07:42 AM
Fireball's Avatar
does anyone else remember 99RedHawk <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
300 shot on a stock bottom end...lived on the dyno (made some sick hp...something like 700+ if I recall) then grenaded at the track...pistons were VAPORIZED haha <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 07-05-2002, 07:59 AM
forced331's Avatar
I would do it. I sprayed a 50hp shot of nitrous on a stock (bottom end 302 with hype pistons)with 14# boost. Car ran fine. I am sure a 350 can handle it. Dont be scared. Just remember if you don't have a separate fuel system for the nitrous (hope it is a wet kit) you will run fat because the FMU brings the fuel pressure up as the boost goes up. Systems are calibrated with the fuel pressure going up but not as much as the FMU takes it. Good luck....
Just don't be scared. Lower the boost as you get more comfortable with the nos. A 50hp will give you more like a 75+hp gain on a supercharged motor.
Old 07-05-2002, 10:11 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fireball:
<strong>does anyone else remember 99RedHawk <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
300 shot on a stock bottom end...lived on the dyno (made some sick hp...something like 700+ if I recall) then grenaded at the track...pistons were VAPORIZED haha <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep I remember Brooke "99RedHawk" His car was taking insane amounts of spray (I actually think it was a little more than that) The car actually dynoed 654 rwhp <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> This was back when the LS1 intake was the only option.
Old 07-05-2002, 10:32 AM
cobrakilla's Avatar
dude, i'm running a 200 shot on a stock bottom end.my best time has been 11.4 on just the bottle.i dont know about 250,but i'm gonna get a cam with some killer duration and run the 250.i still got warranty so i'm ok.by the way, if you are gonna run above 150, go direct port.i got a ls1 pro-pirrana kit from NX,it has not given me any problems.just make sure your A/F ratio does'nt go lean.from what i understand,ls1 bottom ends are pretty strong because they have a 6 bolt main,the only limiting factor i can think of is the pistons.i'll let everyone know how the 250s work out.
Old 07-05-2002, 11:17 AM
BADZ's Avatar
How about if you had a forged bottom end, then how much????
Old 07-05-2002, 04:15 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
Back in 1999, us Chitowners workd on Hacker Joe's car a lot, a stock weight 98Z with purple flames.
Car went 11.4 on 150 NX wet shot.
We added an inline pump, and a 75-100 dry 2nd stage, and it went 11.11@127 right off the highway.
Next time it went 10.89@124mph with some changes to the nozzle placement.
We ran good gas and some race plugs.
Motor lasted about 20 passes but the block got cracked from not running good enuff gas (not enuff octane.
Car was the first LS1 F-Body in the 10's back in the fall of 1999, we beat everybody including MTI.
The day it went 10.89 he drove it to and from the track. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://www.mfba.org/members/images/0070_2b.jpg" alt=" - " />
Old 07-11-2002, 01:38 PM
The Guy in MY 99TA's Avatar
I thaught someone took a Silver z28 and upgraded the fuel system and sprayed a 300 on it and went well into the 10's. I have been to a website on it before I think. If I remeber correctly the car had Bogart wheels on it. They claimed it was a stock car.
Josh S.
Old 07-11-2002, 02:04 PM
LS1Tech Co-Founder
Sure that was 'Silver LS1!' aka Dave P.
He went 10.50 with a stock longblock. He was getting a C5 last time I talked to him.
Quick Reply: Can i run a 250 shot??STOCK MOTOR!
