can't reset TPS.... for the fucking life of me.
Old 09-15-2012, 09:54 PM
rumblebox's Avatar
Default can't reset TPS.... for the ******* life of me.
i adjusted my throttle screw to where the car idles nicely, and i can't get it to reset to zero no matter what i do. i've flashed it like 10 times since then. i've done the "reset procedure" about 20 times with no results. it's still sitting between 4.5% and 4.7% throttle. what the ****???
Old 09-15-2012, 10:09 PM
outkast6991's Avatar
whats the voltage when closed?
Old 09-15-2012, 10:41 PM
rumblebox's Avatar
i'll check tomorrow and get back to you.
Old 09-16-2012, 02:34 PM
rumblebox's Avatar
1.0v closed
5.0v WOT
Old 09-16-2012, 02:43 PM
That would be the issue. I believe you need to be under .6 with the blade closed. You can open up the bolt holes on the tps and clock it until you get the proper voltage or bring the set screw back down and use another method of getting the air you wanted for the idle
Old 09-16-2012, 02:44 PM
Also it can't be above 4.6 or 4.7 at wot
rumblebox's Avatar
I'll just drill the TB
Old 09-16-2012, 03:57 PM
MUSTANGBRKR02's Avatar
What are your IAC counts at hot idle?
Old 10-08-2012, 09:00 PM
bwolfZ28's Avatar
From what I have heard and have had a similar issue...the tps voltage will not reset to 0% throttle unless it is below .70V Try moving the voltage down and then doing a relearn and it should reset to 0%.
Old 10-08-2012, 09:05 PM
rumblebox's Avatar
I just elongated the mounting holes and re-clocked it until it reads 0%. Success.
Old 10-08-2012, 10:05 PM
Russ K's Avatar
The stock WOT voltage threshold is 4.9, but can be changed up to 32 volts with Hp Huners.
The stock min threshold is .15 volts.
Russ Kemp
Quick Reply: can't reset TPS.... for the fucking life of me.
