LS7 Intake and Throttlebody on 1998 Trans Am
Old 08-12-2012, 03:19 PM
Black LS1 T/A's Avatar
Default LS7 Intake and Throttlebody on 1998 Trans Am
So ... what do I have to do (conversion kit, etc, if anything) to make a 90mm throttlebody work with the linkage on my 1998 Trans Am? Anyone know?
I have the LS7 Heads and Intake, Short LS7 Injectors, adaptors for the fuel rails, etc.
Thanks in advance!
Old 08-12-2012, 04:36 PM
ringram's Avatar
Get a cable throttle for it.
Job done.
Old 08-12-2012, 05:30 PM
Job done.
Sorry to sound dense ... I already have a cable that came with car. Do you mean a cable that comes with a Corvette 90mm Throttle Body?
And I'm not really sure what you mean by a "cable throttle".
I also dug this link up up:
https://ls1tech.com/forums/generatio...e-bracket.html
Old 08-12-2012, 08:41 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
The Corvettes are electronic, not cable driven.
If you get an aftermarket throttle body with cable drive, you are good.
You will need a special cable bracket for the LS7 intake as it does not have one on it.
Old 03-27-2013, 12:14 AM
fastcars95's Avatar
Does anyone have a part number for this bracket. I need to order a bracket to use a cable throttle body on a LS7 intake
Old 07-08-2013, 08:58 AM
fastcars95's Avatar
Who makes a bracket for the LS7 intake ?
I see a lot for LS3 intakes. Will they work
Old 07-09-2013, 08:38 AM
LS1MCSS's Avatar
Google and 1 minute found this.
http://www.sfxperformance.com/parts/SLP12509.htm
Old 07-09-2013, 05:00 PM
No Juice's Avatar
That is actually the SLP version, I have heard bad reviews on it.
A bracket that works with the LS3 should work fine. Here is the SDPC one which I have heard good things about
http://www.ws6project.com/user_stor/...oducts_id=4692
Old 07-10-2013, 09:45 AM
fastcars95's Avatar
I ordered the Nick Williams 92 and that bracket.
thanks
Old 07-15-2013, 06:45 PM
No Juice's Avatar
Well, just got my bracket from SDPC, and does NOT fit an LS3 intake.
The bracket hits the #2 runner. Interesting since their site shows it on an LS3 intake with the intake cover on it.
Called and asked them, they said its more for catherdral port intakes such as LS2 and Fast.
Oh well, maybe I can modify it some to fit.
Old 07-15-2013, 08:32 PM
LS1TECH Sponsor
After a lot of aggravation trying to find one that fit, I just built my own from a piece of angle & the LS1 bracket.
Quick Reply: LS7 Intake and Throttlebody on 1998 Trans Am
