LT1 clutch master cylinder
Old 08-11-2012, 05:55 PM
bufmatmuslepants's Avatar
Default LT1 clutch master cylinder
I didnt want to post this in the trans section because the LT1 and LS1 clutches are so different, but:
I need a new clutch master cylinder. Autozone sells a Duralast stock replacement for $69, and Texas Speed sells the adjustabe Tick master for $369.
Is it worth it to spend the extra $300 for the Tick? Im not going to spend that much, Im going to get a stock replacement, but who here uses the Tick?
For those who are still reading, my problem is that when I hold the clutch down it loses pressure and after about 2-3 seconds the car starts to roll forward as if Im letting out the clutch, eventually completely releasing. I already replaced the slave, so the master is the only other option. Ive been driving like this for 3 years now...its a real ******* challenge at the track, I have to wait until I see the 1st amber, toss in the clutch, put it in 1st, bring up the revs, and dump it all by the last amber. Dont have that time if Im doing a pro tree at the shootout...
Also, I have heard that doing a master on the LS1 is a total ******* pain int he ***, even worse than headers, is it so bad on the LT?
Old 08-11-2012, 10:39 PM
Spartan7's Avatar
The Duralast one isn't that great, which is to be expected. I needed one just to get back on the road, and it leaked slightly. I would recommend McLeod, because that's what I have and I like it. I'm not a fan of Tick.
Old 08-11-2012, 11:08 PM
Thats still over $300, are there any that are decent for under $100?
Old 08-12-2012, 02:06 AM
96lt1m6's Avatar
I have used the OE style from the ws6store for many years . Forget replacing part of the set up all or none is the right way here plus bleeding the stock set up sucks and takes forever....
http://www.ws6project.com/user_stor/...oducts_id=4386
i have a TICK PERFORMANCE set up and will never go back to the stock style even for a daily driver! Spend the coin upfront........
http://www.ws6project.com/user_stor/...ster-cylinder/
Old 08-12-2012, 10:01 AM
BALLSS's Avatar
you can buy the whole MC & slave pre-sealed unit for around $125 from rockauto.com
if we are talking LT1 "pull" type clutch
Old 08-12-2012, 10:12 AM
guppymech's Avatar
+1 on changing the whole setup. It's hard to tell if it's the master or the slave that is bypassing. When people only change one cylinder alot of times that doesn't fix it. The GM one is on my list.
Old 08-12-2012, 11:35 AM
fex77k's Avatar
I broke a tab off my slave I bought the whole GM unit for about a 190 at the dealership never had an issue if you replace the whole unit at once.
Old 08-13-2012, 07:33 AM
Sales@Tick's Avatar
There is a reason anyone who has used our master will never use another one again.
Old 08-13-2012, 02:18 PM
guppymech's Avatar
And that reason is?
Old 08-13-2012, 02:54 PM
96lt1m6's Avatar
It does not fatigue like the stock unit, it is adjustable. When and if you get one you will see the difference! Besides the OE replacement is just that......The Tick unit is designed for performance it does not matter if you race your car or just drive it everyday this is an upgrade worth having!
Old 08-13-2012, 06:40 PM
Sales@Tick's Avatar
This guy know the reason!
Old 08-13-2012, 07:40 PM
fex77k's Avatar
Originally Posted by guppymech
And that reason is?
If you are running a stock style clutch then you can get away with a GM unit, but if you start running different style clutches or have to get an aftermarket bellhousing you can run into issues with engagement, then it would make sense to go with the adjustable Tick unit. BTW Tilton makes some damn good stuff, their severe duty starters are top notch.
Old 08-14-2012, 06:41 AM
Very valid point on going with a Tick, but they are SO DAMN EXPENSIVE I can get a new clutch for that much
Old 08-14-2012, 06:50 AM
DAVE00's Avatar
I know it's been said before, but look around for a McLeod. I found one used for around $150 a few years back and they are incredible pieces. Even if you find one used they are completely rebuildable with a kit from McLeod with all of the replacement seals, good investment and the adjustability is very nice.
Old 08-14-2012, 08:39 AM
Are the LS1 and LT1 masters the same? I know the slaves are not
Old 08-14-2012, 08:43 AM
katz_2003's Avatar
I bought a tick master and I love it! You can definately feel a difference on the engaugement. My centerforce was having problems with the stock master but with the adjustable one from tick it solved my problem.
And yes, the ls1 and lt1 masters are different. I believe the main part of the unit is the same from tick performance but the lines are different.
Old 08-14-2012, 10:27 AM
Rockauto sells a prebled master and slave for $93, anyone use theirs before?
Old 08-14-2012, 03:29 PM
Sales@Tick's Avatar
Our masters use Tilton hydraulics
Old 08-17-2012, 09:18 AM
LS1TECH Sponsor
Joey@Tick's Avatar
Our Tick Performance Adjustable Clutch Master Cylinder Kit for LT1 F-Body is $324.99 and we offer Free Shipping on any order over $100: http://www.tickperformance.com/tick-...or-lt1-f-body/
Our kit is capable of flowing more fluid than any other master on the market, making it more adjustable than any other master cylinder. We also warranty it against leaks and/or failure for life. It's more expensive than any OE type cylinder, sure, but it's also a much, much higher quality product.
Old 08-17-2012, 12:20 PM
96lt1m6's Avatar
Joey@Tick
I said this before in another forum and i will say it again.....
I thank your company for taking the time to provide the Lt1 crew with newer products. we have a great crew of die hard race fans in the Lt1 world and we will always be competitive!!!!!!!!
Quick Reply: LT1 clutch master cylinder
