Is this a reverse flow water pump? How else could this work?
Old 07-31-2012, 11:44 AM
Cobra4B's Avatar
Default Is this a reverse flow water pump? How else could this work?
EDIT - Nevermind I found the guy's post on here from 2006. He custom made a reverse rotation pump (same flow path) by machining his own impeller and pulley.
Researching belt routing options I cam across this...
This would spin the water pump the opposite direction. Does that work? Or is this a reverse flow pump or something?
Quick Reply: Is this a reverse flow water pump? How else could this work?
