abs light help
Old 07-25-2012, 09:01 AM
PurpleHaze9414's Avatar
Default abs light help
Had abs traction control break light steering assist light and steering light came on scanned car got a b0550 a b0896 b0898 says ecm ecm voltage . i looked at ecm appears fine anyone else ever experience this?
Old 07-25-2012, 09:25 AM
The_Madcat's Avatar
I believe a failing hub/abs sensor could cause this. How many miles on the front bearings/hubs?
Old 07-25-2012, 11:05 AM
WMCC NICK's Avatar
I have all the same lights on, Mine ended up being the whole ABS module. It had low output voltage coming out of the ABS module.
Old 07-25-2012, 06:41 PM
I bet its abs module it says low voltage how much did that cost u?
Old 07-25-2012, 09:31 PM
WMCC NICK's Avatar
The couple I found where $500+ for new, I might go the used route, its half the $ and from what I hear its not a common problem, so hopefully it will last. But still not sure, which way to go.
Old 07-27-2012, 03:15 PM
neilownz's Avatar
ABS fixer might fix them. I know on my truck you can run without the module, but the light stays on or something.
Old 08-02-2012, 09:59 AM
Has anyone had there abs traction break and variable effort steering light go off bc of low break pads?
Quick Reply: abs light help
