Temp sender re-thread
Old 07-24-2012, 07:28 PM
86SS86LS's Avatar
Default Temp sender re-thread
I've read that it is common to cut down a stock sbc temp sender to fit the 12X1.5 threaded hole in the head. The sender I have is 1/2 npt and is quite a bit larger than the 12 mm hole. Can I safely remove that much material from the sender without messing anything up? And for my own understanding....what is inside the temp sender?.....How does it work?
Old 07-24-2012, 07:37 PM
Pop N Wood's Avatar
I tried turning down an M14x1.5 sender to fit and it ripped in half when I tried to tighten it. Hard to imagine getting a half incher down to that size.
There is just a small electronic thermister, a hard piece of plastic with two electric leads, inside the hollow brass tube.
In fact, I have had a stock one twist in two with just slightly too much torque.
Your best option is to drill out the head and retap it or relocate it to a different spot. Lots of options for that.
Old 07-24-2012, 07:38 PM
zuffen's Avatar
I re-taped my head ti 1/2" NPT without any problems.
The temp sender has a small thermocouple inside it who's resitance varies with the temp of the water surounding it.
There aren't any moving parts inside.
Old 07-28-2012, 12:10 AM
86SS86LS's Avatar
Looking through the local salvage yard, I see that some of the 90's gm vehicles have a 3/8 npt sender. Could this be cut down and threaded to 12X1.5? I'd rather modify a sender than the head.
Old 07-28-2012, 03:09 AM
85GPLEf41's Avatar
Contact LS1MCSS, i just got a temp sending unit lathed down to the proper thread specs and his pricing and shipping was great!!
Old 07-28-2012, 06:03 AM
99VetteFRC's Avatar
I tapped the head to a size of one of the adapters that came with my mechanical guage.
Old 07-28-2012, 07:20 AM
garys 68's Avatar
I doubt you can turn down 1/2" to fit in the head. The drivers side brass block plug is the perfect size to drill the interior (allen head) and tap for 1/2" npt.
Old 07-28-2012, 11:50 PM
billyflantos's Avatar
i tap'd my waterpump for my old camaro and truck and it work'd like a charm....
Old 07-29-2012, 05:53 AM
LS1MCSS's Avatar
You are correct. The 1/2" senders won't turn down small enough. I tried an old one I had here and cut completly through it way before it was small enough. I start out with the 3/8 senders and cut them to 12MM.
Old 07-29-2012, 10:57 AM
86SS86LS's Avatar
How much for a sender?
Quick Reply: Temp sender re-thread
