Project Red Headed Screamer: Destroked 6.0, 333ci 12.5:1, twin 6468s, faceplated T56
Old 07-13-2012, 12:36 AM
Jakson's Avatar
Default Project Red Headed Screamer: Destroked 6.0,12:1, C5-R heads, solid roller, S485
Not quite your average budget build here, straying off the path from most a little bit. I'll start with a little story of how the year started off for me, and how the build plan came about.
It all started the day I took my car out of storage in February. I wanted to bring my car back home so I could work on it, and get it all ready to go for the summer. With the addition of the FAST 90, and billet MAF ends, it was rather lean at WOT. I figured I was going to pick at the tune some myself, and see what I could find and learn a thing or two. I drove it 120 miles from storage at the parents place, back to my house. When I pulled into the garage with the window down, I heard a dreaded valvetrain tick. Great.
So the next day I drove it to work, and pulled the valve covers in hopes of finding a broke spring, or bent pushrod. No such luck, everything looked just fine and in working order. So at that time I decided I would just put it back together and run it as is, in hopes it would come out of it. If it scattered parts on the floor, so be it. Bolted the car on the dyno up at work, and flogged on it for the day just having some fun and practicing tuning on it. Made it through the tuning session alive, and tuning picked up 30 rwhp. The noise was still there loud as ever. So I drove it back to storage to let it sit, while I came up with a new plan. On the drive back to the parents it got worse, and eventually I could feel it start to miss. Did a few top end pulls, just to make sure I could really see the damage when the time came to pull it apart.
Fast forward a few months, I had come up with a plan to build a nice NA 370 with the parts I have, buy some good heads to put on it and make 500rwhp. Around that time is when my buddy Nathan at One Guys Garage was finishing up his new 5.3 turbo setup, and was planning on bringing it up to TPIS for a dyno session. Well, when his stock 5.3 made 820hp with just a little turbo, it got me thinking. Of course I knew about turbos and how easy they were to make power with, I just didn't have the means to make a kit myself. After talking with Nathan for a while following the dyno session, we decided he could whip up a kit for me, and I too could have some turbo'd LS fun.
So that's when the turbo build planning began. I knew I wanted to keep AC being its a street car, so we decided a truck/c6 manifold kit would be the ticket. So with most the details worked out, all that was left to do is pull the engine and start buying parts! Sorry mostly cell phone pics for now, better high quality camera pics to come.
Pulling the engine:
What I found inside:
One other lifter also had a roller wheel axle falling out, put a nice gouge in one of the other lifter bores as well.
So with everything apart, time to get to work with the new build. Here are the details!
Details of the car:
98 Z28 6 speed
Liberty Factplated T56
SPEC Super Twin P-trim
Tick Adjustable Master
Moser 9" 31 spline, trutrac, 4.11's
BMR Turbo K-member
UMI Solid Motor Mounts
Engine setup, machined and built by yours truly:
Iron "5.3" 332ci on E85, ARP head/main studs, custom coated diamond pistons, callies rods, stock crank.
Ported LS3 heads, LS3 hollow stem intake valves, LY6 inconel exhausts, PRC EHT springs
LS9 headgaskets
239/243 .625/.625 116lsa Comp Cam
Morel link bar lifters, 3/8 pushrods
9.5:1 Compression Ratio
Turbo/Fuel setup:
Precision PT8847 .96 A/R turbo
Truck/C6 manifold/4" downpipe turbo kit, keeping AC, with stock radiator location, built by Nate at One-Guys-Garage.com
Precision 46mm Wastegate
RPS 50mm BOV
LS3 intake
Bosch 240lb High Z injectors
Triple 340 LPH fuel pumps
Some may be wondering how I am going to fit LS3 heads on a little old 5.3. Well, I'm using a 6.0 block .020 over, and a stock 4.8 3.267" crank.
Going with the 4.8 crank mostly to try something different, boost will be my replacement for displacement in this case. Somewhat similar to the new COPO Camaro 5.3 engine setup. Hoping to turn it 7500+, obviously the stock intake will be the limiting factor somewhere along the line.
I will most likely go to a single plane later on. Just going to get it running in this configuration first, work out the bugs and go from there.
Final hopes/goals for the build are 20-22psi max, and 850+ rwhp of tire shreading, gear ripping fun. Let me know what you think!
Few pics of the parts and progress so far, plenty more pics and updates to come!
Results so far: 1092hp flywheel @7600rpm boost creeping to 20psi, 992hp@7000RPM/798tq@6100RPM on solid 16psi
Old 07-13-2012, 01:57 AM
Nitroused383's Avatar
Pretty unique setup you got going on there. I think it will run pretty damn hard. Liljohn on yellowbullet has talked about this setup for a while now. Can't wait to hear how it runs.
Old 07-13-2012, 02:12 AM
skinnies's Avatar
850rwhp shouldn't be a problem, my jy 5.3, auto, 7675 made 855rwhp on 24lbs, your better engine, 6 speed, and better turbo will easily make up for the 2psi loss!
Old 07-13-2012, 09:49 AM
JoeyGC5's Avatar
Subscribed! This is a simular motor combo I've wanted to do for the last two years.
Old 07-13-2012, 01:05 PM
Gingervitis Addict
slow67's Avatar
Subscribed!
Old 07-13-2012, 03:58 PM
9sectruck's Avatar
you should be able to spin that b---- to the moon with that short stroke. good luck on the build
Old 07-13-2012, 04:49 PM
mehoffz24's Avatar
in for results
Old 07-13-2012, 05:08 PM
NemeSS's Avatar
I think that motor will make alot of hp even in n/a form. Would b cool if u could get a n/a baseline before psi
Old 07-13-2012, 06:06 PM
Jakson's Avatar
This will happen. I'm starting the engine build now, should have it ready to run and dyno it N/A this fall. Then hope to dyno it with the turbo setup as well!
N/A, I'm thinking it will be in the 530-550hp range at the crank.
Old 07-13-2012, 07:27 PM
NemeSS's Avatar
And it should pick up a good chunk if you upgrade to a fast 102 over the ls3 eventually.
Old 07-13-2012, 08:49 PM
miatainthe10s's Avatar
Thought about this very motor combo after I bought parts
. Haha Subscribed!
Old 07-14-2012, 09:27 AM
LS1NOVA's Avatar
Here's a couple more pictures for you.
I like how the front turned out with the grille. Will look a little more stealth than the typical open bumper.
Old 07-18-2012, 10:20 PM
Jakson's Avatar
Oval piping showed up, using that since the downpipe will be on the drivers side. Not exactly sufficient clearance on the drivers side for a 4" round DP on the good old fbod's. Then just a cool pic with the bumper off
Old 07-19-2012, 12:56 AM
Turnin20s's Avatar
^^^Damn thats a cool pic
Good progress, I want to see how this turns out
Old 07-19-2012, 05:07 AM
Outlaw666's Avatar
Im looking forward to seeing the results on this one.
and thats a nice clean shop!!!
Old 07-19-2012, 07:28 AM
typhoon1015's Avatar
geeze, clean up that dirty shop nate!
looks good, how much is that oval stuff?? If you order more I might want a piece as well.
Old 07-19-2012, 07:51 AM
68 SS's Avatar
Should be a screamer with the short stroke hope your new valve train is up to the task of controling the big intake valves as mentioned above it will spin to the moon esp seeing how it is a stick shift car but I would hate to miss a gear!
Old 07-19-2012, 02:05 PM
78novacaine's Avatar
Nice build, and that is probably one of the best looking z28's I have ever seen!
Old 07-30-2012, 06:48 PM
LS1NOVA's Avatar
Had some time to get back on this project a little today. Just need to finish the wastegate outlet into the downpipe and the left charge pipe then its ready for welding.
Old 07-30-2012, 06:56 PM
BottleFedZ346's Avatar
Very nice build!
Quick Reply: Project Red Headed Screamer: Destroked 6.0, 333ci 12.5:1, twin 6468s, faceplated T56
