1st pass with 5.3 = 2 broken, 1 torched piston ???
Old 07-08-2012, 11:21 AM
JAX04's Avatar
10.2 On E85, interesting, how does it run usually? Do you typically target that? I only ask because on 10.3ish, i fouled NGK BR7EF plugs very quickly.
Secondly, id be intersted to see how your fuel checks out.
Those autolites, what heat range do they compare to vs an NGK?
Im not convinced the IATS were the real problem here.
As far as "feeding the blow torch", I personally dont think so. I believe 11.5 is to lean for E85, just becuase you dont get knock doesnt mean you are making peak power...
Old 07-08-2012, 11:27 AM
JAX04's Avatar
Are those 103s projected Tip plugs? Also, not sure, but it looks like their are equiv. to a NGK TR6...
Also, im no expert, but it looks like i see signs of Detonation AND pre ignition... Which i believe is why that one piston literally looks torched...
Old 07-08-2012, 02:12 PM
jleews6's Avatar
Witch is one of the reasons I said double check the fuel system before running it again. It doesn't cost anything to flow the system and clean everything.
Old 07-08-2012, 03:47 PM
GrahamHill's Avatar
Poor lil pistons lost their oil, overheated the rings, and the rings not only try to grip the cylinder wall but they also expand in the land and crack themselves and try to split in lands, one from another.
Old 07-08-2012, 04:29 PM
tta656's Avatar
Sorry to hear the bad new...if you dont mind please tell me about the twins and how do you like them on the street,driveablity,turbo lag?...and pic of the setup..very interested in this
Old 07-08-2012, 04:37 PM
1989k1500's Avatar
Originally Posted by a4ls2goat
Holy intake temps!
With my dual nozzle meth and a small intercooler my intake temps start at 105* and end at 85* .
Your IAT sensor is probably after the meth nozzles, he is throwing in e85 after the IAT sensor.
Old 07-08-2012, 04:44 PM
MillsMotorvation's Avatar
I to burnt #7piston in my 5.3, Im ordering a used on from ebay as we speak! Cylinder has a small nick, but this is my practice engine, so Im learning to tune on this one! I think the 11.7 afr was to lean, and intake temps of 154 took it out! Good luck!
Old 07-08-2012, 09:07 PM
quik67's Avatar
I chose a 10.2 afr to stay on the safe side with that much boost and no cooling of iat. The Autolite 103 is equivalent to a NGK TR6
Old 07-08-2012, 09:13 PM
quik67's Avatar
I believe it probably went lean also. It was running really hard thru first gear, and started popping severely after hitting second gear then pretty much layed over in high gear.
I had to add 10% fuel to get it to crank the next day, just to get it off the trailer. I am thinking my Megasquirt picked a bad time to start crapping out.
I am going to re-do all my efi wiring and double check my fuel system before the next engine goes in. I also found 5 bent rods on the other pistons that were fine.
Old 07-08-2012, 09:16 PM
6 Second Club Moderator
LASTLS1's Avatar
What was your injector duty cycle?
Old 07-08-2012, 09:42 PM
quik67's Avatar
My turbos are GT35 ebay clones. I knew going into turbos I would probably
break some stuff so cheap turbos and a cheap engine were on the menu.
I have no complaints whatsoever with these turbos.
My cam had the biggest effect on turbo lag until i put a looser converter in it.
Now it is pretty seemless. I went with a 4500 stall nitrous converter that I already had. If your cam isn't too radical, lag shouldn't be much of a problem.
Old 07-08-2012, 09:46 PM
  #32
quik67's Avatar
I didn't datalog the run, I wish I did now! However it has been around 80 to 85%
Old 07-08-2012, 09:50 PM
  #33
black98ws6ta's Avatar
Too rich (IMO), and too much timing for non intercooled 18 psi.
Old 07-08-2012, 10:50 PM
  #34
I8UR4RD's Avatar
yeah but hes running e85, that should account for some temp control. too bad he didnt log it though.
to the OP, how much boost had you been running prior, and what was the tune like at that point in time?
Old 07-08-2012, 11:12 PM
  #35
BLINGOLE's Avatar
get your iat' under 150, run 10.6-10.8 afr on gas scale with e85 and max 18degs. stay below 16lbs and it'll live forever.
Old 07-08-2012, 11:57 PM
  #36
Its not easy to log the change in air temp of the e85 being sprayed out of the injector anyways.
I have alittle experience with e85 and 5.3's. Ive put almost 30 psi to a stock motor that did go down the track quickly without blowing up.
Old 07-09-2012, 12:06 AM
  #37
trav-tech's Avatar
e85 = fail.
Old 07-09-2012, 12:09 AM
  #38
quik67's Avatar
Prior to this I was running 15 psi, 10.7 afr, 17 deg timing.
Yeah, I wish I had logged it, now its just speculation.
Old 07-09-2012, 12:30 PM
  #39
MaxxMitchell's Avatar
Looks like it went lean, torched a few pistons, and heated the rings on the other.
I am in the progress trying to blow up my 5.3 back up motor, non intercooled, E85, 30+ deg at 19-20lbs. 60+ full hard passes later on the street and its still running fine with no blow by.
Old 07-09-2012, 01:38 PM
  #40
Cooldude5231's Avatar
"why johnny ringo, looks like someone just walked over your grave" ;]
Quick Reply: 1st pass with 5.3 = 2 broken, 1 torched piston ???
