Old 04-25-2016, 05:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension Guides
Print Wikipost
ls1 lifter noise
Old 07-03-2012, 07:47 PM
ws6_34's Avatar
Default ls1 lifter noise
i have a 2001 pontiac trans am m6 i just recently did a ms3 cam swap in my car and also did luntai dual valve springs with seats, retainers, locks, seals, locators and tsp hardened 7.4" pushrods, ls7 lifters, a melling high volume oil pump and a ls2 strengthened timing chain. about a week after i did this it started making a really bad ticking noise sounded like a lifter and a teacher at my school (uti) said i had a collapsed lifter so i replaced them again and its still making the noise. ive checked the lifter pre load multiple times, checked the cam bolts to make sure they werent backing out, ive checked my header bolts multiple times and none of it fixed the problem. friday night i pulled the valve covers back off to check the rocker arm geometry and when the rockers where off i went ahead and pushed on the pushrods to see if the lifters would plunge and both the lifters on cylinder 7 would plunge. im not sure if this is from them bleeding down too fast or not getting adequate oil to them. any help is greatly appriceated since i have been going at this for about 3 weeks now and havent figured out whats wrong.
thanks, collin
Old 07-03-2012, 09:12 PM
crainholio's Avatar
How much lifter preload are you running, and how did you measure it?
Old 07-03-2012, 10:22 PM
SStressin's Avatar
noramlly valvetrain noise is from not having the correct pushrod length from what i have been reading
Old 07-04-2012, 04:07 AM
LS1-450's Avatar
If the valve wipe pattern is good, there is no problem. Lifter noise (sounds like a sewing machine) is common. The more you load the rockers, the more noise you're gonna get. I believe that it's the heavily loaded needle bearings in the rockers. Others will claim that it's the dual springs. Personally, I've never heard a spring make a noise from compressing & unloading. It's the higher spring force from the dual springs applied to the needle bearings in the rockers that makes the sound, IMO.
#7 is last to get oil & first to drain. Don't worry about being able to push the pushrod into the lifters there. Again, if the valve wipe pattern is good, there is not issue.
Old 07-04-2012, 10:05 AM
ws6_34's Avatar
i have 1/2 a turn of pre load after zero lash to 22 ft lbs and ive been told that is in the range of what you want to have. ive also checked to see if one of the trunions where just taking a crap on me from this high lift cam and spring pressure but they hardly had any side to side movement when bolted down and also didnt feel like they had a bind in them when i checked them with them off the car. and will cylinder 7 lifters bleed down 30 mins after the car has been off? i didnt know they would bleed off that fast
Old 07-04-2012, 10:08 AM
ws6_34's Avatar
ohhh and also this isnt the normal ls sewing machine noise the valvetrain makes. this is more of a tapping noise that increases frequency with rpm
LS1-Mike (04-24-2022)
Old 07-04-2012, 10:24 AM
Darkman's Avatar
That preload is only 0.024" (uncorrected) or 0.0133" (corrected) which is quite small. I think the minimum acceptable preload is larger.
See:
https://ls1tech.com/forums/generatio...re-load-2.html
Old 07-04-2012, 10:41 AM
ws6_34's Avatar
how did you figure out .024"?
Old 07-04-2012, 10:50 AM
ws6_34's Avatar
ohh well i called texas speed and they said with the ms3 cam and 7.4" pushrods u want from 1/2 turn to 3/4 of a turn after zero lash.
Old 07-04-2012, 10:51 AM
Darkman's Avatar
The method that specifies preload based on the number of turns (aka Shane's method) assumes 0.047" to 0.049' of preload for each turn, which is 0.024" of 1/2 turn. This "flat-rate per turn assumption" is a little off, but usable within the applicable range. (Corrected numbers are contained in the other thread I referenced.)
Old 07-04-2012, 10:53 AM
LS1121's Avatar
Read Darkman's attached link.
Old 07-04-2012, 03:53 PM
therabidweasel's Avatar
The amount of preload you need is not determined by your cam or pushrods...it is the lifters. 1/2 to 3/4 seems pretty light to me, that is what is used on short travel lifters.
Old 07-04-2012, 06:14 PM
ws6_34's Avatar
ok well i just replaced the oil pump o ring and i drove it for 20 mins and it never made the noise. and thats just what texas speed said it should be within 1/2 to 3/4 of a turn
Old 01-26-2016, 12:28 AM
Llchunky B Bashir's Avatar
Okay guys I have a question. I have 2002 ss six speed camaro. I jus recently like yesterday came to the same problem over again. I replace my lifters my cam my timer chain. Resurface my heads an re done my valves an. THe o ring We let the car run for like 20 mins after we put everything together. At first it wasn't no ticking then I drove an the ticking came back again. Smh an my oil gauge jumping Again An I ask my friend that replace my lifters how long did he let them soak in oil. He said for like a hour or two So I'm askin could that been the problem. My lifter was suppose to b in oil longer
Old 01-26-2016, 12:57 PM
gagliano7's Avatar
The lifters sitting in oil isn't your problem. They pump up in 5 minutes. I have morel 5315 lifters and the said just coat with oil no need to soak them. No problems here. Make sure you don't have an exhaust leak. Since your gauge is jumping around maybe you pinched the o-ring installing it.
Quick Reply: ls1 lifter noise
