Looking to get my tail lights normal.
Old 05-28-2012, 07:39 PM
kevinbushman's Avatar
Default Looking to get my tail lights normal.
The guy I bought this car from mentioned it had a minor accident which caused the replacement of the left rear quarter panel and the tail light to be replaced as well. The quarter panel is great but take a look at my tail lights.
http://imgur.com/a/oZrhZ
It looks like the driver side light fixture was replaced with some strange non-oem part. I guess the auto body shop he took it to didn't care about making sure the lights matched.
It causes two problems.
  1. Everyone tells me I have a light out on my drivers side.
  2. Moisture is always found inside the reverse light.
So I guess my question is: Can you help tell me what the part # is for the OEM light so I can fix these two problems? Any other suggestions or thoughts?
Old 05-28-2012, 07:44 PM
TempleU_WS6's Avatar
The picture isnt working, but check out ebay, theres a good amount on there.
Just saw one for $175, buy it now; not a bad deal.
Old 05-29-2012, 12:05 AM
Thanks. Pictures are working now. $175 is fantastic. I will check it out.
Old 05-29-2012, 04:05 PM
PUNISHER TA's Avatar
Maybe the replacement was tinted... I dont think anybody makes aftermarket tails for T/As...
Id try wet sanding it a bit to see if it lightens up. (also, black tinted water)
Old 05-29-2012, 04:13 PM
stevesfbody's Avatar
wet sand and buff will take care of it
Old 05-29-2012, 04:25 PM
Nemesis350's Avatar
yeah that's actually common to see. something about the reflective material inside the housing corrudes or flakes off if water leaks in... ??? Not really sure but again i see it EVERYWHERE, and the stranger thing is that it alway seem to be the driver side
Old 05-29-2012, 04:39 PM
lilpb1's Avatar
I agree with Nemessis350 they probably replaced it with a used or it may have water inside causing the reflective material to peel off.
Old 05-29-2012, 04:58 PM
therobman's Avatar
here u go
http://www.ls1.com/forums/f36/how-re...rd-ws6-163800/
Old 05-29-2012, 05:36 PM
Super-Bat's Avatar
^Neat. I thought the 98+ Taillights were NOT able to be separated.
Old 05-29-2012, 05:51 PM
HotWhipT/A's Avatar
Yea, that's what we've all been told. I guess that guy didn't get the memo and figured it out! Turns out you can, but it ain't easy! That write-up is very good.
OP - It's the inside that is the problem just like in that write up. The outside isn't the issue, but a little polishing wouldn't hurt to get rid of some swirls.
Hawks Third Gen has used ones for $150. New is too expensive there. If you want a new one, WS6 store is $299. Search 10431949 for the LH (Driver side) and10431948 for the RH
Old 05-29-2012, 05:53 PM
Originally Posted by therobman
Dude! Awesome, thanks for that. This and possibly in combination with the wet sanding mentioned above might save me a couple hundred bucks!
I hadn't even thought to look around for a fix since I assumed it was a defect from a non-OEM part.
Old 05-30-2012, 02:04 AM
BadBirdie's Avatar
same problem i've had with my drivers side tail light as well! thanks for posting that write up therobman, i will be trying that soon!
Quick Reply: Looking to get my tail lights normal.
