Can you mix plugs of the same brand?
Old 05-19-2012, 10:49 AM
Caseythefalcon's Avatar
Default Can you mix plugs of the same brand?
So I had 7 ngk v power plugs and one other brand that had a cracked insulator..idk who did it..just bought the car. Would it be fine if I just swapped out that cracked one for a ngk g power platinum? Or should I replace all of them with ngk platinums. The v powers all look fairly new.
Old 05-19-2012, 11:01 AM
355z28's Avatar
Just put another V power in it.
Old 05-19-2012, 01:14 PM
nitrous2fast's Avatar
You can put in what ever you want.....
that being said, if you put a platinum plug in your car, you should do a search on spark plugs,
Old 05-19-2012, 03:08 PM
F0x Slaughter's Avatar
Standard Copper plugs for the win.
Old 05-19-2012, 04:54 PM
Nobody has answered my question.....I don't see why its so hard
Old 05-19-2012, 05:08 PM
Lets look at this here.
A V Power cost under 3 dollars a plug.
So 3 x 8 = 24.
So behind all logic, swap all the plugs at once.
Platinum and Copper have different properties.
Platinum plugs retain heat burning themselves clean, thus giving a greater chance for detonation as they are hot longer.
Copper dissipates heat quicker. They don't last as long due to this feature.
Do a simple search on copper vs platinum and you will find a lot of information on this subject.
Old 05-20-2012, 08:18 AM
Speedy's Avatar
No, it won't make any difference at all.
Quick Reply: Can you mix plugs of the same brand?
