how tall of a tire? 26s or 28s?
Old 05-17-2012, 10:23 AM
Banned Scammer
BashamWS6's Avatar
Default how tall of a tire? 26s or 28s?
Alright ive loked everywhere and cant find a straight answer.
I have 99 ws6 with bolt ons. soon to be d1sc with 411s thru a s60
what tire should i put on my weld 15x10s?
Old 05-17-2012, 03:00 PM
MM98's Avatar
Definitely go with a 28".
Old 05-17-2012, 03:37 PM
Banned Scammer
BashamWS6's Avatar
will that fit under my fenders? and would i need adjustable lcas? and what if im lowered?
Old 05-17-2012, 03:55 PM
MM98's Avatar
I'm running 275/60's & have BMR 1" springs.. I just had to roll the fenders.. I'm using Spohn non-adjustable lca's & the tires are pretty centered with no clearance problems. But I'm also on a 9" Convo pro rim w/ 6.5 bs. The 10" rim w/ a 7.5 bs might need the bump stops trimmed & inner fenders hammered if you're lowered.
Old 05-18-2012, 02:40 PM
Banned Scammer
BashamWS6's Avatar
would i need tubes for that? and i know i will need spacers for the fronts.
Old 05-18-2012, 06:18 PM
Captain Double Post
BOBS99SS's Avatar
28s for sure, i run a 275/60/15 if your lowered pending on how much you will at least need to roll fenders/maybe a lil bh etc nothing to crazy,
Old 05-18-2012, 06:49 PM
blackls1ta00's Avatar
ta's have alittle more room in the wheelwell,275/60/15 should fit without any problems,if anything just alittle of a bfh
Old 05-19-2012, 11:06 AM
SF 1HOTLS1's Avatar
if your a 6spd car or an auto with a t brake then a 28. if your an auto with no trans brake, then a 26. i have an auto with no t brake and a 28 just lowered my 60ft times. if you dont have the force of dumping the clutch then a 28 will slow u down imo. its just to tall of a tire and needs that force from a 6spd or t brake to get it going.
Old 05-19-2012, 02:24 PM
edwardzracing's Avatar
I disagree that 26" would be the way to go with his car. A supercharged car with 4.11's is not going to have any problem getting out of it's own way. My recommendation would be a 28" tire for sure. Otherwise you're sure to run out of gear at the top end.
Old 05-20-2012, 01:32 PM
blown97ss's Avatar
i agree with a 28 i personally have a 26 in my car with 373s if i spin off the line in i red line the car at the end. if it dead hooks i finish the pass at the very top of my 3rd gear. you will be out of gear in a a4 car with a 26 and 411 gears.
Old 05-22-2012, 06:15 PM
flintwrench69's Avatar
I was told dont use tubes unless you use screws in the rim to prevent the tire from spinning or you could rip the valve stem of the tube & there goes all your air pressure. Tubes also add more weight.
