4.8 t6 s472....it's only the beginning....
Got my buddies 4.8 in the f body tuned up last night. 9.5 psi from a t6 1.10 83mm s472....runs really good for what it is full spool by 3800 with 6 speed. it brake spools 9.5...which is awesome lol....car needs another 255 and 8an feed and a good regulator and a boost controller and it will see 15 to 20 psi. has 80lb injectors and was 90% duty cycle...so it was running out of pressure somewhere lol
Specs:
2008 4.8 55k miles
Ls9 cam
Ls7 lifters
Tsp 7.4 pr
Afr dual springs
243 heads
Ls1 intake
6 speed
3.42 gears stock 10 bolt
Specs:
2008 4.8 55k miles
Ls9 cam
Ls7 lifters
Tsp 7.4 pr
Afr dual springs
243 heads
Ls1 intake
6 speed
My mistake....when I hear the term "foot braking" I think of a car at the tree at a drag strip building boost and getting ready to launch.
yes pump only last night....car has a meth kit on that we will be running 100% meth very soon...just ordered another pump....the car had 2 walbro 255's in it but I sold the car without the fuel system, the bucket is already for 2 pumps so its just a drop in deal
Im running 28* timing until 3500 then ramp down to 18* by 4500. Im pretty rich arond 11:1 the whole time it is spooling up, any leaner and it seems to spool slower. What kind of timing and AFR are you running while its spooling?
Do you have a line going to the top of your wastegate and boost controller or just run it off the spring and bottom port? Im just on the bottom ports. I wonder if my gates are opening slightly and slowing spool up?
yea we started at 2500 in 3rd gear af was 11.5 starting and 12.0 at top end 6700, but having fuel problems...80lb injectors were 90% duty cycle but I am fixing that today. No boost controller yet just spring pressure. car has a Tial 44mm gate referenced from the buttom port goin right to the turbo. timing is 20* afr is 11.5-12.0
your gates could be opening up...what kind? what is your setup?
