Gen 5 Camaro Tuning, Diagnostics, Dyno results Tuning problems, solutions, dyno results for Gen 5 Camaro
Whipple 416....
Old 05-02-2012, 07:56 PM
Rhino79's Avatar
Default Whipple 416....
I had the pleasure of dyno tuning a pretty nasty setup today. It's an Orange SS, 416, 2.9 whipple, th400.
The plan was setup 2 tunes, 1 for each pulley. 3.75 and the 2.75.
Long story short, we didn't have a short enough belt for proper tension on the 2.75 and it shredded...lol. That pulley would be good for about 16 psi. So we only got to setup the 3.75 which is only 8psi.
It put down 661 on 8 lbs at 6750.
Car had gone 9.84 at 138 before the can swap on 8psi. Hopefulley the belt will be here Friday to setup the tune for the big boy pulley. I'll post a quick idle vid shortley.
http://www.youtube.com/watch?v=ubJS8uj4fKY
Old 05-04-2012, 08:44 AM
FLYZNTN's Avatar
Very nice. I really, really would love to go to a forged bottom end. Very interested to here about the 2.75 and whether or not that 6 rib is going to work out.
Also, I'm curious about the boost and pulley size you're running. On the Whipple site the 3.75 pulley should produce 11 pounds at 6500 rpm and the 2.75 is 19. I am running the 3.875 on a stock bottom end and am making pretty close to what whipple says I should be (10 pounds).
Interested in getting my mind around why there is a difference. I assume that the extra cubes and cam, as well as, head work and opened exhaust would account for this. Correct?
Old 05-04-2012, 11:26 AM
Rhino79's Avatar
This is an 8 rib setup and yeah it varies from setup to setup on boost
Old 05-04-2012, 12:39 PM
FLYZNTN's Avatar
Aha! That makes sense. I've seen 6 rib setups slip on 3.75 setups so I was curious. Did you get the new belt for the smaller pulley?
Old 05-09-2012, 03:28 PM
Rhino79's Avatar
Well the 3.25 is the limit for us, any smaller and we are overrunning the blower. At 11.5 psi it made 721 through a th400 and a monster converter.
Old 05-16-2012, 09:59 PM
navyblueSS's Avatar
Very nice!
Old 06-10-2012, 04:12 PM
whipped416's Avatar
should of beem able to run the 2.75 with 10 rib setup that is what im running... should make about 17 pounds of boost. and around 800 rwhp... need a 102 nw tb...
mine is getting tuned this week!! hke 416 with 10 rib whipple and ported heads cam. should be a nice setup.
rhino did this car have ported heads?
what was the cam spec?
Old 06-19-2012, 07:55 PM
Rhino79's Avatar
Yes ported heads and it was only 8 rib. The nw102 he has is shutting the blade over 6500 rpm so thats a lil roadblock. He is upgrading to the upcoming 4.0 Whipple so I don't know how much more we'll play with this setup.
Old 06-20-2012, 04:28 PM
blackonblacksls's Avatar
15s in the front?
Old 07-07-2012, 12:17 AM
whipped416's Avatar
new 4.0 whipple is still a long way out! i talked with mike as whipple and its not even on the plan right now until they get some other more in demand units out..
Quick Reply: Whipple 416....
