Drag Racing Tech
Venting valley cover?
Old 04-26-2012, 08:49 AM
MM98's Avatar
Default Venting valley cover?
I was thinking about just welding a -12an bung to the front of the valley cover & venting into a breather tank.. Would this be sufficient enough for a 346 H/C/I motor w/ nitrous? I'd much rather do this instead of running breathers on the valve covers, if it will work. Thanks!
Old 04-26-2012, 10:19 AM
tektrans's Avatar
Valve covers are the highest point to vent from, have u considered putting bungs on the valve covers and plumbing to a catch can?
Thats what I did.
Old 04-26-2012, 10:28 AM
armyboyatc's Avatar
Not trying to hijack but isnt oil consumption worse from the valve cover area than the valley cover?
Old 04-26-2012, 10:32 AM
MM98's Avatar
Thats what I did.
Yes, I actually have -10 bungs to do the covers.. Just thought a single 12 from the valley would look a lil cleaner.. So you're just venting from both valve covers to a single breather tank?
Old 04-27-2012, 06:22 AM
tektrans's Avatar
I actually used 2 catch cans and I used the stock valley vent also.
Old 04-29-2012, 06:56 AM
Firehawk441's Avatar
I accually used 2 catch cans and I used the stock valley vent also.
You did a nice job with the install BUT.....
It would've been nice if that engine accually ran in your car before you parted it out and sold everything.
Old 04-29-2012, 08:18 AM
tektrans's Avatar
Hahahaha, this is true.
Your motor did look alot better under my hood than my old motor, I should've at LEAST started the thing up before I sold it-hahaha
Old 04-29-2012, 09:01 AM
ATwelveSec02Z28's Avatar
youll get less oil out of the valve covers vs the valley if you vent from the valley in the from the front.
If it is in the mid region of the valley cover it may be better.
I had my vacuum pump pulling from the front and would pull 1/4 qt of oil on a run.
Old 04-29-2012, 09:35 AM
Can't compare a vacuum pump to just crankcase ventilation.
Quick Reply: Venting valley cover?
