88mm turbo 5.3 blow thru camaro
Old 04-14-2012, 09:25 PM
lsx74camaro's Avatar
Default 88mm turbo 5.3 blow thru camaro
almost completed, i know a t6 88mm turbo is to big for this combo but a 100 shot should help and the 5.3 is just a tuning/ test dummy i dont expect a long life span ,building a 6 liter
Old 04-14-2012, 09:37 PM
Adam86's Avatar
HOLY HELL that thing is massive! I assume this mostly a strip car? Looks good!
Old 04-14-2012, 09:51 PM
yeah it looks a little smaller with that 5" inlet pipe, its going to be a street strip car.I was just getting sick and tired of my bbc 468 always running hot and always having problems, this day and age turbos the only way to go. Also has air to air intercooler and meth injection cause i want to run mostly on 91 octane.
Old 04-14-2012, 10:30 PM
Specs are majestic 88 mm t6 .96 a/r turbo ,coolingmist meth injection ,nitrous, junkyard 5.3 lm7 ,z06 cam, springs, 241 heads. homebuilt log style manifolds, msd controller, 850 holley annular boosters, brpv, gm performance single plain, th400 with gearvendors o/d, tci 3000 stall ,tci transbrake ,3.42 gears, hoping for low 10's
Old 04-15-2012, 06:37 PM
chiaj144's Avatar
Interested in seeing the results. I live just up the road from you in Prescott. I had a blow through for a couple of years got sick of messing with jets and the ford ****. I am putting a 5.3 into my mustang but with a smaller turbo. I'd like to check your car out sometime.
Old 04-15-2012, 11:21 PM
Adam86's Avatar
Got any pics of the whole car? Would love to see it!
Old 04-16-2012, 03:27 PM
There is a pic on my profile. I have pics of the build, I think ill post them.
Old 04-16-2012, 03:32 PM
Kool anytime, it seems like im the only one in my area till now doing this stuff. All i see in morrisburg at cruise night is retired people with stock old cars lol.
Old 04-16-2012, 05:33 PM
SSZ
SSZ's Avatar
Whereabouts is morrisburg? I am in Caledonia just south of Hamilton. I have a 5.3 in my 80 Z28 and am going turbo. Just got Hp tuners. How far are you guys from me? Any idea?
Old 04-16-2012, 08:51 PM
chiaj144's Avatar
We're about 4 hours from you.
Old 04-16-2012, 10:09 PM
Everything was built by myself, nothing was sent out.Some of it isnt the most professional looking but i dont care lol. Oh and more less everything you see is used, either off ebay or local classifieds only gaskets, head studs, carb hat, ebay valve covers are new
Attached Thumbnails 88mm turbo 5.3 blow thru camaro-img_7832.jpg   88mm turbo 5.3 blow thru camaro-img_8012.jpg   88mm turbo 5.3 blow thru camaro-img_8089.jpg   88mm turbo 5.3 blow thru camaro-img_8087.jpg
Old 04-16-2012, 10:28 PM
More pics and in second pic i lucked out i bought the piping used with a knock off tial bov (i replaced it with a real one) from a guy with a tuner car already welded all 3 inch with a intercooler for 150.00. One cut and it fit perfectly in the camaro.
Attached Thumbnails 88mm turbo 5.3 blow thru camaro-img_7428.jpg   88mm turbo 5.3 blow thru camaro-img_7434.jpg   88mm turbo 5.3 blow thru camaro-img_8016.jpg   88mm turbo 5.3 blow thru camaro-17137_278832522656_517367656_3805765_2110624_n.jpg   88mm turbo 5.3 blow thru camaro-18637_316135657656_517367656_3926993_5929974_n.jpg
Old 04-16-2012, 10:36 PM
And some more last pic is a day trip to vermont to pick up a lq4 short block, i knew having a minivan was for more than hauling the kids around.
Attached Thumbnails 88mm turbo 5.3 blow thru camaro-img_7432.jpg   88mm turbo 5.3 blow thru camaro-img_8019.jpg   88mm turbo 5.3 blow thru camaro-img_8073.jpg
Old 04-17-2012, 03:20 PM
mmarlow21's Avatar
I am running a blow thru setup on a small block but want to go with a 5.3 yours looks good bet it runs good to and if it dont just spray it some more
Old 04-17-2012, 06:36 PM
SSZ
SSZ's Avatar
Ok, so you guys must be up around Ottawa way. LSX74, is that a stock truck oil pan? Have you driven the vehicle yet and if so how does it feel and how is the spool?
Chiaj144. IIRC you were looking at a S480 to purchase. I saw that on another forum. Did you end up getting one?
Old 04-17-2012, 10:32 PM
On the final stages of assembly havent had it running yet ,but i am assuming its going to be laggy and not going to spool the greatest. The guy I bought the turbo off said it would be best suited for a around 400 cubic inch engine. I bought the turbo before the lsx idea came.I was going to originally use the turbo my 468 bbc but it would be too small. Right now the 5.3 is a test dummy for tuning blow thru and mock up. I was thinking on getting a t6 to t4 adapter and getting a cheap t4 turbo until i build the 6 liter (stroker kit?)but why waste money, thats where some nitrous comes in to play. The oil pan is a truck oil pan. I was going to to the gm muscle car oil pan thing but i herd alot of guys having problems with clearance with inner tierods and my car isnt lowered and with a turbo engine i wanted to keep the 6 liter oil capacity. I had the oil pan anyway so instead of taking a chance and spending over 200 dollars and buying the swap oil pan that might not fit i took that money and got a pure argon tank and a aluminium conversion kit for my welder and welded the pan. It fits like a glove.
Old 04-18-2012, 07:48 PM
mpatton's Avatar
Lmfao i thought inwas the only one thats fit a motor inside my car, ! Mine was upfront though, buckled in so.it didnt kill.me on the way to the machine shop
Old 05-02-2012, 10:01 PM
Turbo inlet completed ,amazed it fits under hood
Old 05-02-2012, 11:41 PM
NemeSS's Avatar
so far, so good
Quick Reply: 88mm turbo 5.3 blow thru camaro
