1,870 HP so far.. New Texas Mile Build
Old 03-20-2012, 02:21 PM
ls1muscle's Avatar
Default 1,870 HP so far.. New Texas Mile Build
Top Speed Corvette C5 Z06
Built and Tuned by Hinson Motorsports
4-27-2012
We have arrived at the Ohio Mile!
3-23-2012
Unfortunately, we had to postpone the trip to Texas. We simply ran out of time to test before the race, and that is a long haul to ride untested. So we're planning to attend the Ohio Mile, which has 4 events this year. We'll be tested and ready.
3/23/2012
New numbers are in!
2,246 HP @ 7,800 RPM
34 psi
3-20-2012
We made our first pulls on the engine dyno! We made 1,870 horsepower on low timing and 27psi. We're turning up the boost and timing tomorrow. We'll run out of injector around 2,400 horsepower. Special thanks to Young's Performance, Lane Culver, Butler Performance, Ryan Carpenter, Buddy Anderson, and Noah Mitros for making this happen so quickly.
http://www.youtube.com/watch?v=kChVR...layer_embedded
3-20-2012
We are headed for the Texas Mile on March 23-25! We are thrashing to complete the project now (3/20/12). We ran 224 mph on low boost with our previous build. We're looking to beat our own record and eventually compete for the world record for the fastest piston powered car. This new car is a combination of C5 and C6 parts resulting in extreme performance. We have built on the information gained from our previous car, and this ride is looking to push the boundaries for standing mile racing.
Build Specs
Shortblock
427ci RHS Aluminum Tall Deck Block (Assembly & Machining by Butler Performance)
Callies Ultra Center Counter Weight Billet Crankshaft
Aluminum Connecting Rods
Diamond Pistons
Custom High Capacity Oil Pan from Doug Lee Engineuity
Top End
TEA Trickflow 245cc Cylinder Heads
Crower Roller Rocker Arms
Comp Pushrods
Custom Comp Solid Roller Camshaft
GM EFI Carb Style Intake Manifold
Turbo System
Custom Turbo Setup with 118mm Turbo
5" Downpipe
Custom Air/Water Intercooler
Tial Blow Off Valves
Tial Wastegate
Computer & Fuel
Holley EFI Dominator System
Bosch 160 lb Injectors
FuelLab Fuel Pumps & Regulator
Transmission & Rear Differential
RPM TR6060 Transmission
RPM ZR1 Differential with Quaiffe LSD
SPEC Twin Disk Clutch
Roll Cage & Body
25.5 Roll Cage
Custom Adjustable Rear Wing
Wheels & Tires
True Forged Wheels 18x12 & 18x10
Hoosier R6 Tires 345/35/18 & 275/35/18
This is a custom tall deck 427ci solid roller engine built in partnership with Butler Performance. The guys at Butler Performance handle our big cubic engine builds. These RHS blocks are great when they're in capable hands of a great machine shop. Give us a call to help plan your next race engine build.
Getting ready for the engine dyno.
Amazing craftsmanship by the guys at Hinson Motorsports.
Shameless plug for our friends at RHS & Total Engine Airflow/TrickFlow. We stock and use these great manufacturers for our personal and customer use. Let us know how we can help you assemble your next combination of parts!
RHS intake spacers for the tall deck build.
Forced air enters here. Intake is a GM piece with custom fuel rail solution by HINSON Motorsports. An intake elbow plate has been bolted down to the top. We will custom fabricate the elbow to work on this engine.
A billet alternator bracket built by Lane here at the shop. Got amps?
Custom water plates for -12 AN cooling connections. Built in house at Hinson Motorsports.
Custom high capacity oil pan with trap doors for fluid control.
Custom external oil pressure regulator on race oil pan.
Amazing craftsmanship by Buddy & Lane at HINSON Motorsports. Great work guys!
118mm Turbo - It's bigger than you think.
Don't get sucked in
5" Downpipe.
Lots of boost = Twin BOV.
Funny car cage for driver protection. Still under progress when picture was taken.
This is an all business interior featuring a 25.5 cage for protection.
Intercooler and engine water tanks in the trunk. All fabricated in house.
Running a TR6060 and ZR1 differential with Quaiffe LSD. Thanks to RPM Transmissions for their support on the initial build in 2011.
SPEC Twin disk from last year's C6 race car. Thank you SPEC for the continued support in 2012.
High rise hood to clear the intake elbow.
Custom adjustable rear wing.
Rear wing support for additional drag and down force. Braces supported by custom structure built behind the rear bumper.
True Forged 18" wheels.
Looking to put a "2" in front of that horsepower quote.
Old sticker from previous life as a single turbo 76mm. Kinda funny in today's form..
Old 03-20-2012, 03:00 PM
nodrok's Avatar
How much boost you running this time?
Old 03-20-2012, 03:03 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Damn.
best of luck out there, thing looks sick!
Old 03-20-2012, 03:22 PM
ls1muscle's Avatar
Just added the engine dyno video.
Old 03-20-2012, 04:07 PM
Nitroused383's Avatar
Wow that thing is sick, looked like it broke the dyno mounts ?
Old 03-20-2012, 04:14 PM
93camaro_zzz's Avatar
Mother of god! Nice build! Hinson sure is doing a great job!
Old 03-20-2012, 05:37 PM
93formto98T/A's Avatar
Nice build. Can't wait to see what she'lll run. How do you speculate 2400hp of injector with 160s? Also, why the low gearing?
Old 03-20-2012, 05:49 PM
venom ws7's Avatar
Good luck with that beast...
Are you guys planning to use 5th & 6th gears with 3.42 gears?
Old 03-20-2012, 06:47 PM
4WardInv's Avatar
super nice build, good luck with the run!
Old 03-20-2012, 09:51 PM
9sectruck's Avatar
it def broke a mount on something at the end of the pull
holy **** that thing sounded like it was 10k rpms
Old 03-21-2012, 09:00 AM
V-seriesTech's Avatar
Awesome to see a C5 aiming to get it done. Best wishes.
Old 03-21-2012, 09:19 AM
the SS show's Avatar
Did kelley bise make you angry with his runs? haha
That's an awesome builld. I look forward to seeing it down there
Old 03-21-2012, 11:47 AM
427's Avatar
Cool build, good luck with your race!
Kurt
Old 03-21-2012, 03:57 PM
02anti_vnm's Avatar
i dont believe it broke a mount it did the same thing in the video of the previous build. click on the link "previous build" its a pretty damn cool video except for the wreck at 230mph at the end
Old 03-22-2012, 06:26 AM
Boo"SS"t's Avatar
Holy crap!!! your wastegate is almost the same size compared to one of my upgrade turbos......
Old 03-22-2012, 11:23 AM
2baditsnotachev's Avatar
Wow awesome man, I can't help but notice your not running the steam ports on the heads? Love the alt. Bracket, looking forward to the video at the mile!
Old 03-22-2012, 02:33 PM
ls1muscle's Avatar
New numbers are in!
34 psi
Old 03-22-2012, 02:37 PM
GulfM3's Avatar
Originally Posted by ls1muscle
New numbers are in!
34 psi
WOW, nice numbers
Are you going to make it to the mile?
I'm heading down friday after work, I'll keep an eye out for your car.
Old 03-22-2012, 02:38 PM
tt383lt1's Avatar
you got all that hp out of some bosch 160lb injectors? are the injectors high or low imp and was it hard to tune the injetcors
Old 03-22-2012, 03:17 PM
venom ws7's Avatar
New numbers are in!
34 psi
Quick Reply: 1,870 HP so far.. New Texas Mile Build
