6.0 build questions
Old 03-14-2012, 10:04 PM
Restricted User
kalebm22's Avatar
Default 6.0 build questions
i have an lq4 6.0 block. i am buildint this engine for my whipple supercharged 2002 4x4 sierra. i make about 10lbs of boost on my 5.3 and i am running a 3200 circle d converter, longtube headers, no cats, straight thru muffler, electric fans and i have 33" tall tires, ported throttle body.
my parts list so far
lq4 block
lq4 crank
lq9 rods and pistons
im thinking
224ish custom grind cam from lloyd elliott
valvsprings from him
probobly work a set of ls1 heads over a little if i can find a set cheap.
otherwise i have the 98 ls1 heads that are perimeter bolts. not sure if they are worth it or not.
im also going to run the patriot extreme springs.
would a set of arp rod bolts be a good upgrade?
im going to send the crank and rods to the machinshop to get turned.
block will get honed and cam bearings installed.
is there any input or things im missing here? any info is appreciated
Old 03-14-2012, 10:33 PM
chopperman69's Avatar
Rod bolts for sure.
Off subject, but how's your trans holding?
Old 03-14-2012, 10:37 PM
Restricted User
kalebm22's Avatar
haha well so far so good..... definately getting the rod bolts then
is there a part number for the bolts i need?
Old 03-15-2012, 03:03 AM
93Z2871805's Avatar
134-6006 for the ARPs
Old 03-15-2012, 05:13 AM
mark21742's Avatar
If you do get heads and port them your psi will drop for the same given amount of air flow, plus you will get cooler denser air so you can make more power. I'd look st something like a 224/230 .595/.595 115-116lsa
Old 03-15-2012, 07:20 AM
Restricted User
kalebm22's Avatar
Ok, I may send the heads to Lloyd elliot and have him do a valve job and some porting if I don't donor myself. Will the lower air temps and less psi be easier on the engine?
Old 03-15-2012, 07:31 AM
redtan's Avatar
How much boost do you plan on running? Also, why not a cheap set of 317s to flow better than the 241s and also lower the compression ration given that you're putting in flat top pistons on a boosted application?
Old 03-15-2012, 09:07 AM
Restricted User
kalebm22's Avatar
Well I'm making about 10lbs on my 5.3 so I'm guessing 7 ish PBS of boost. I figured the lq9 pistons and rods would be stronger. I already have the perimeter bolt 806 heads just laying here. I don't have any 317s. I figure 9.5 to 1 compression is what I would shoot for
Old 03-15-2012, 11:56 AM
93Z2871805's Avatar
There's always the option of using 04-later LQ4 pistons, they're floating and use the Gen IV rods.
Old 03-15-2012, 01:19 PM
Restricted User
kalebm22's Avatar
Ok I just found out the lq4 block, rods, an pistons came from a 2007 2500 box van. So I'll need a crank signal converter right? And also are those the good rods and pistons?
Old 03-15-2012, 02:07 PM
mark21742's Avatar
Yes that should be a 58 tooth crank, so you need the converter box.
Old 03-15-2012, 04:26 PM
Restricted User
kalebm22's Avatar
ok, who sells the box?
also i dont have the front cover or sensor for the crankshaft so would i be better off to have someone change the ring out with a 24x ring i have here?
Old 03-15-2012, 04:33 PM
mark21742's Avatar
The crank sensor sits right above the starter on the passengerside....I think you are thinking of the cam sensor....gen 3 is at the back, right behind the intake, and the gen 4 is in the front cover. I'd just call some local junkyards, or even do a search in the forsale section here for the front cover.
Old 03-16-2012, 12:01 AM
Restricted User
kalebm22's Avatar
ok that makes sense, i was confused. do i need the gen 3 cover so i can run the same cam sensor off of my 5.3? also does annyone know who sells the converter box or know what it is actually called. i cant find it.
Old 03-16-2012, 12:07 AM
93Z2871805's Avatar
I'm pretty sure if you run the signal converter, you run all Gen IV hardware and sensors (white cam and crank sensors), and let the box handle the signal. You would use a Gen IV cover and cam gear for the sensor to read it and be converted by the box. I think Lingenfelter makes that module/box.
Old 03-16-2012, 01:00 AM
mark21742's Avatar
If I'm correct to go from the gen 3 to gen 4 cam sensor all you have to do is cut and lengthen the sensor wires and run them to the front cover
Old 03-16-2012, 02:06 AM
bww3588's Avatar
Or You can just buy a cheap extension harness. If he buys the converter box, it will come with it.
You can't run a gen 3 cam in a gen 4 engine block. There is no provision for the cam sensor on the back of the engine. You will need the front cover, sensor and reluctor wheel.
Old 03-16-2012, 07:24 AM
Restricted User
kalebm22's Avatar
That's quite a bit of work. Is it possible to just change the rings?
Old 03-16-2012, 07:32 AM
97badass's Avatar
My 04 lq4 block has pressed pins...
Old 03-16-2012, 10:16 AM
Restricted User
kalebm22's Avatar
What's that mean?
