Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
knock sensors?
Old 03-11-2012, 12:55 PM
streetknight2's Avatar
Default knock sensors?
Do you use them on a carb application? Do they have to be installed?
Old 03-11-2012, 03:07 PM
richard david's Avatar
Not used with carb
Old 03-11-2012, 03:21 PM
In-Zane Moderator
ZONES89RS's Avatar
They serve only as a eye sore.
Old 03-11-2012, 10:46 PM
billyflantos's Avatar
knock sensors can be your best friend or your worst enemy...and no,you dont need them with your carb.
Old 03-12-2012, 05:31 AM
Pop N Wood's Avatar
If you were to do something like use the stock computer to run the ignition then you could use them, but the MSD box has no way of using them.
Old 03-12-2012, 02:36 PM
I'm using MSD box. Do I need to plug the holes in the block with something, install them, just no wiring, or does it matter?
My first rodeo with a LSX based engine.
Old 04-19-2012, 09:24 AM
RabidStreetRacer's Avatar
I have the same question. I new I didn't need them, but do you just remove them from the block or leave them in and just don't hook em up?
Old 04-19-2012, 10:36 AM
RATBOX's Avatar
You can just leave them in there, it won't make any difference either way.
Old 04-19-2012, 10:58 AM
lsx74camaro's Avatar
Pick up an msd knock sensor box around 230.00 i think and plug them into that, mine works great, you dont want detonation and you should monitor it . I blew up an engine that way. Expensive lesson learned. Some say you can hear knocking but with a modified engine and loud exhaust good luck hearing it.
Old 04-19-2012, 01:43 PM
Prorac1's Avatar
I also have an MSD knock sensor that I have used on past carb applications. It works well. Eric L
Quick Reply: knock sensors?
