Custom center console & radio bezel
Old 02-28-2012, 01:43 AM
lymlyt96's Avatar
Default Custom center console & radio bezel
I switched to the trans am console and noticed the gap between it and the radio bezel so I wanted to extend the bezel down to close the gap and at the same time make a home for my pioneer f500bt which is a portable navi unit that can be paired with a phone and hardwired into the car.
Here's how I started with radio. I cut the bottom out of the bezel and made a simple frame out of fiberglass...
I changed the design a few times why I don't know maybe because nobody was there to tell me to stop
This is the radio bezel finished..
Now for the center console I had to get a bit creative to figure how I was gonna pull this off, so I glassed the ash tray hole and cut a slot for my iphone, kinda slick but I didn't stop there. I bought an iphone dock and mounted it so the phone sits high enough to where it doesn't affect my shifting and I can still see the name of who's calling. The phone dock is connected to the navi and the navi is connected to the amps so everything works together...
And the gauge underneath the bezel is a scangauge 2 which works pretty good.
Old 02-28-2012, 08:58 AM
bad_408_vert's Avatar
Great Work!
Which Iphone dock did you use?
Old 02-28-2012, 09:10 AM
f-body.cbct's Avatar
Wow! Looks like you've done a lot in there bro! Looks good!
Old 02-28-2012, 12:37 PM
lymlyt96's Avatar
Originally Posted by bad_408_vert
Great Work!
I found a $5 dock on ebay that was made for automotive use, if you have a deck with ipod hookup you plug the cord into the dock instead of the phone and set the phone into the dock. For 5 bucks it wouldn't hurt to try it out.
Old 03-01-2012, 04:41 PM
lymlyt96's Avatar
finished the center console but I'll have to paint it over or wetsand it because someone picked it up and left a nice fingerprint in the clear
Old 03-04-2012, 03:26 PM
camaroboy14's Avatar
Wow that looks so bad ***!!
Old 03-04-2012, 05:51 PM
pillarpod's Avatar
whats that thing under the navi?
Old 03-04-2012, 11:32 PM
14k
14k's Avatar
does the phone holder havea charger at the bottom?
and it needs to be more refined it looks just like a hole in the console. i like the idea.
Old 03-05-2012, 04:25 PM
lymlyt96's Avatar
The phone holder does have a charger underneath and I'm going to place a chrome ring on the edge of the hole because it does look unfinished. The thing underneath the navi is a scangauge 2 it reads and clears engine codes, shows mpg, iat, open loop, map and can even calculate horsepower along with a bunch of other readings from the PCM
Old 03-05-2012, 04:56 PM
whytryz28's Avatar
That is nice.
Old 03-06-2012, 11:19 PM
GoodSpeed150's Avatar
I really like the Ipod dock! Good idea
Old 03-07-2012, 05:43 AM
LE35thSS's Avatar
the phone holder thing is genius! looks really good.
Old 03-07-2012, 08:09 PM
lymlyt96's Avatar
Thanks for the kind words fellas I cant wait to set everything up together and hit the road I haven't had music in my car for at least 3 years, the sound of the exhaust was all I needed but now that song is gettin old.
Old 03-07-2012, 09:57 PM
greendrazil's Avatar
Just what I was thinking to make!
Old 04-04-2012, 12:39 PM
Mike96z's Avatar
Just wondering, what kind of paint did you use? Automotive paint or some type of interior paint?
Old 04-04-2012, 11:01 PM
JOHNNY59's Avatar
dam that's alot of work!
Old 04-04-2012, 11:36 PM
lymlyt96's Avatar
I ended up using duplicolor gloss black spray paint and the duplicolor paint shop clear coat. I've been wanting to try the paint shop system for a while, you can get it at most auto parts stores and its already pre mixed so its convenient. It's not the best clearcoat but it still turned out really good for what it is.
Old 04-04-2012, 11:48 PM
Mike96z's Avatar
hell I couldn't tell, looks automotive quality in pictures at least.
Old 04-05-2012, 09:25 PM
jbro90's Avatar
How did you paint th center console and the radio bezels man like the process
Old 04-06-2012, 12:23 AM
lymlyt96's Avatar
After the body work was done I sanded with 400 grit sandpaper, cleaned the pieces with a prep spray to get rid of oils and dirt, let it dry wiped it down with a tack rag then sprayed a primer sealer then the black spray paint and finally the clear was sprayed with an hvlp gun.
Quick Reply: Custom center console & radio bezel
