What fitting for Corvette power steering pump?
Old 02-27-2012, 11:51 AM
samckitt's Avatar
Default What fitting for Corvette power steering pump?
Trying to find a fitting for a C5/C6 Corvette power steering pump to steering box. Is this what I need:
http://www.detroitspeed.com/products...tlt-fttng.html
Old 02-27-2012, 07:43 PM
S10xGN's Avatar
That's the HP port from the pump to the rack. The one from DSE will have a different flow/pressure rate than a stock GM fitting. Why are you changing it?
Old 02-27-2012, 08:20 PM
samckitt's Avatar
I don't have anything presently. I was under the impression I would need a special fitting for it. Do I just get a GM fitting for it?
Old 02-28-2012, 07:38 PM
S10xGN's Avatar
I ended up with a reman from Advance and the fitting came with the pump...
Old 03-14-2012, 09:37 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
If you want to install a fitting in the Corvette pump that has a AN-6 out, then Earls makes one.
Andrew
Old 03-19-2012, 10:43 AM
thenovaproject's Avatar
M16 1.5 to an6
Quick Reply: What fitting for Corvette power steering pump?
