345/40/17 on a 17x11
Old 02-13-2012, 06:38 AM
wannabfast's Avatar
Default 345/40/17 on a 17x11
Hey guys I'm wondering if 345/40/17 tires will fit well on my 17x11 zr1 wheels with out any rubbing. Will I be able to lower my car at all?
Old 02-13-2012, 07:44 AM
69TA's Avatar
forget about rubbing
that tire is way too big for that wheel
Old 02-13-2012, 08:13 AM
82cetuner's Avatar
its also going to be 28 inches tall I have seen 335s on a 11 that fit just fine, it might be ok on a 11, look at the overal width and rim recommendation
Old 02-13-2012, 08:48 AM
wannabfast's Avatar
ok thanks didnt think it was gonna work but wanted to double check found a deal on some tires. Thought it wouldnt hurt to get second opinion
Old 02-13-2012, 10:40 AM
green95vert's Avatar
I run 335/35/17s on a 17x11. THey bulge but they fit, wouldn't go any wider than that but with that taller sidewall you MIGHT be ok. Don't recommend it though.
Old 02-13-2012, 10:57 AM
69TA's Avatar
there is no point to running such a wide tire on
that skinny of a wheel.
your contact patch area is compromised on account of the squeeze effect
so besides having less area to roll on you are also getting premature wear
down the middle of the tire and also carrying extra weight (rubber) with less contact area
Old 02-13-2012, 08:53 PM
jsmith309's Avatar
I run 315/35 17. Fits perfect. No need for wider
Old 02-13-2012, 11:38 PM
warriorcustoms's Avatar
11in rim for a 315/35ZR17 is perfect Gettin 2 of my speedlines widened to do it Thatll be with Eibach Pro Kit springs on my 95 Ram Air Trans Am
Old 02-14-2012, 12:29 AM
98BLOWNZ28's Avatar
I wish my rear wheels were 12" wide.....
Old 02-14-2012, 12:31 AM
Fast T's Avatar
315s are the biggest im going on my 17x11.
Old 02-14-2012, 09:19 PM
meine96ws6's Avatar
I ran 315 on my chrome zr1's.... they bolted on perfect and didn't rub any..
I was lowered on eibach pro kit and was able to center the rear perfect with adj panhard
Old 02-17-2012, 07:27 PM
mikh338's Avatar
as a few others said, i also am running 315/35/17s on 17x11 wheels lowered 1.5 with eibach pro kit and have zero rub or any issues
Quick Reply: 345/40/17 on a 17x11
